CK30 oil change and oil condition
   / CK30 oil change and oil condition #1
Retired guy
Bronze Member
Western, ME
CK 30HST
Just finished the 50 hour oil @ 59 hours. The oil coming out was the same color as
the stuff going in--light tan. No soot - no discoloration. On my Kubota, it was black
after about 5 hours on the clock. Is this common?? I was expecting maybe a little
MORE discoloration due to the newness and the fact that the rings had to set, etc.
My serial # begins with an M. Could this be a newer Tier engine?
   / CK30 oil change and oil condition #2
I don't know about your bota but multi weight oils usually discolor fast. What oil you using now?
Rotella T-6. I do not know what came in the engine.
   / CK30 oil change and oil condition #4
How do you like the Kioti compared to your Bota? Check the color of this oil after ten hours.
   / CK30 oil change and oil condition #5
Break in oil is usually non detergent and will not darken as quickly.
   / CK30 oil change and oil condition #6
The factory oil would be non-synthetic; and if you're not seeing a lot of evidence of break-in particulate matter that is not necessarily a bad thing. I seem to remember thinking the same when I drained mine the first time too.
Welcome to TBN and don't forget to add the Kioti to your avatar sig!:thumbsup:
John 4 x 4 cart (A50323)
John 4 x 4 cart...
2019 Ford Explorer AWD SUV (A50324)
2019 Ford Explorer...
Caterpillar Front Glass (A50854)
Caterpillar Front...
2020 SOUTHERN WELDING PNEUMATIC SAND TRAILER (A50854)
2020 SOUTHERN...
2000 SPARTAN SUMMIT RV (A50854)
2000 SPARTAN...
2018 PETERBILT 579 TANDEM AXLE SLEEPER (A51222)
2018 PETERBILT 579...
