MtnViewRanch
Elite Member, Advertiser
- Joined
- Mar 19, 2005
- Messages
- 10,679
- Tractor
- Mahindra 7520, Mahindra 3215HST, Case 580 extendahoe, Case 310 dozer, Parsons trencher, Cat D6,
Is this method right then?
1) Position Tractor
2) Place in neutral
3) Set Brake-Chock tires too? No need to chock the tires
4) Lower Auger tip to ground
5) Depress clutch
6) Engage PTO into 540 RPM Position
7) Set Throttle (How many RPM?) Idle works for me
8) Start drilling and lower 3-Pt lever all the way down-monitor drilling Move the lever down as the auger digs in.
9) Increase RPM to clear hole- do not raise auger out . Finish hole. Raise the auger every 12" of depth to clear the dirt, just don't raise it out of the hole. No need to raise the RPM.
10) Disengage PTO (depress clutch, PTO lever back to off)
11) Raise auger out of hole
I've even seen some video demos where the tractor is moved forward as the hole is drilled in order to maintain a verticle hole. Is this a good practice or required? Depends on the size of the hole and what you are using it for
1) Position Tractor
2) Place in neutral
5) Depress clutch
