CK30 Front end loader not lifting heavy loads
   / CK30 Front end loader not lifting heavy loads #31
Hmmmm, if no leaks we are saying no air nor oil could allow for movement of piston and rod one way or the other?
Leaking piston seals would just allow flow of oil past piston when circuit is open?
Interesting lesson.
   / CK30 Front end loader not lifting heavy loads #32
Interesting lesson.
The rod can be pulled out of the cylinder because the volume inside of the cylinder would be increasing when that happens. Which is why I suggested lifting the front wheels of the tractor with the loader. If the piston seals were leaking bad enough to make any difference the tractor would settle back to the ground pretty quick. The rod cannot be pushed into a cylinder without loosing fluid somewhere. Rather it goes back through the valve, leaks out of a hose somewhere or leaks out the gland seal. Both sides of the cylinder are already full and pushing the rod in takes up space that’s not there to take up. Anyone that says otherwise go fill up a glass completely full with water and stick your hand in it without spilling any water. The theory is that the fluid from the barrel end of the cylinder bypasses the seal and goes into the rod end of the cylinder. That can’t happen because the barrel end holds more fluid and the rod end was already full to begin with. How are you going to put more fluid in less space that was already full when you started? A leaky piston seal could cause loader valve to leak down faster.
   / CK30 Front end loader not lifting heavy loads #33
Wouldn’t there be airlock if air couldn’t get in??
   / CK30 Front end loader not lifting heavy loads #34
It would pull a vacuum which would make some resistance but not a lot. Have you ever pulled out a syringe with your finger over the end and let it snap back down?
   / CK30 Front end loader not lifting heavy loads #35
Yup. Was thinking that if piston seal failed, could you pull piston through the oil or would the lack of anything flowing to fill the void left by the rod volume leaving the cyl prevent the rod from being pulled out?
   / CK30 Front end loader not lifting heavy loads #36
Hi folks:
My 2008 CK 30 with 760 hours is having trouble lifting a pallet of firewood. This is a task that it used to do routinely with ease. The loader can still lift two 12-14 foot logs (must weigh 200-300 lbs total). It can also raise and lower through the complete range of motion.
regards,
DOC
Another thing to keep in mind is, logs roll to the back of the forks, the pallet spreads the load out to the end of the forks, where your tractor has LESS lifting power.
SO, it will pick up heavier logs than it will lift a pallet of wood.
SR
   / CK30 Front end loader not lifting heavy loads #37
SR
It wouldn’t take much of a pallet of firewood to overwhelm the 1500 pound rated loader and anything I’d consider a log would weigh way more than 150 pounds in a 14’ chunk but he did say the loader would lift it before.
Folks:
Many thanks for all of the advice. I did the leak test and it was fine!
Therefore, I did a little experiment today and I have to admit I am red faced with embarrassment. Over the past couple of years my firewood logs were mostly: box elder, maple, white birch and beech.
I changed suppliers and this year my firewood log pile is made up of mostly black, white and green ash, some cherry, maple and oak. I checked the relative weights of the various species and you guessed it: a full pallet of the wood I am cutting this year weighs about 25-30% MORE than what I was moving last year.
No wonder the tractor can't handle a full pallet. I feel like a dumb *****! for troubling you all.
However, the other problem still remains:
When it is below freezing the joystick is frozen. Some people suggested that there was water in the mechanism.
On this tractor the joy stick is connected to the hydraulic valve underneath by what appear to be cables. The joy stick boot is cracked. While the tractor is stored in an open sided shed, it has been operated in the rain.
What do you suggest I do to remediate the issue with the frozen joystick in cold weather?
Thanks a bunch.
DOC
   / CK30 Front end loader not lifting heavy loads #39
Heat gun or hair dryer to dry it out, then replace the boot.
   / CK30 Front end loader not lifting heavy loads #40
It is very possible you have moisture in the cables and they are freezing. Don't force the joystick. Frozen cables need to thaw. If the boot leaks, replace it.
2021 Freightliner Cascadia 116 T/A Day Cab Truck Tractor (A55973)
2021 Freightliner...
3518 (A57193)
3518 (A57193)
UNUSED IRANCH 14' BI-PARTING GATE (DAMAGED) (A57193)
UNUSED IRANCH 14'...
UNUSED FUTURE CL100 HYD CLAMP GRABBER (A57193)
UNUSED FUTURE...
Year: 2015 Make: Ram Model: 5500 Chassis Vehicle Type: Truck Mileage: Plate: Body Type: 2 Door Cab; (A55852)
Year: 2015 Make...
JOHN DEERE 560M LOT NUMBER 28 (A53084)
JOHN DEERE 560M...
