ck27
   / ck27 #1
bullet20
im looking for a bottom plow for my ck27 . what will it pull? single or tandem??? and a bush hog sizes??
   / ck27 #2
The plow requires traction (weight), the bushhog requires HP.
The CK27 is a rather heavy tractor for its power.
According to the PTO HP, a 4' cutter would be perfect, but wont cover your tracks. So I'd get a 5', you pay just have to slow down in places.
As to the plow, you have a pretty heafty tractor. It will probabally pull a large sincle bottom, like a 16", or two smaller bottom plows, like a 10 or 12.
I'll let other who actually have a ck27 chime in now.
   / ck27 #3
I have the Bobcat version of the 27. I use a 4' cutter only becasue that is what I had with the older, smaller Kubota and often find myself going too fast with it. If I had more land to mow I would trade it for a 5' or 6'.
I don't plow but was looking for 1 before I came across a good buy on a tiller, was thinking of single 16" or 2 12". I think a 2 bottom 14" is a little big but depends on the soil type.
   / ck27 #4
I have a 5 ft. bushhog on my ck25 and it works real well.
   / ck27 #5
I use a 10" double-bottom plow with mine. Pulls it great.
This summer I used a 5' bush hog and it did very with it. It did bog down some in really thick, tall stuff. But, in the machine's defense, I had the bush hog set way low. Simply raising the 3ph a little when it bogs fixes it. I mowed a lot of saplings and tougher stuff with ease. Don't fear a 5-footer. 6' would be pushing it.
   / ck27 #6
Ck25hst with a 2-bottom plow works fine on LOW (fast enough to turn the heavy clay soil/grass). 5' finishing mower also works like a charm!
   / ck27 #7
My CK27HST pulls a single bottom plow without any effort in low. Ditto for a 5' box blade with all rippers set low. If bog down just raise the 3pt a bit and it will go on.
Heavy Duty Hydraulic 84" Broom  (A52384)
Heavy Duty...
2014 BOMAG BW 213 DH-4 (A52472)
2014 BOMAG BW 213...
2012 MACK CXU PINNACLE (INOPERABLE) (A52472)
2012 MACK CXU...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
CATALYST INJECTION TANK (A52472)
CATALYST INJECTION...
2020 CHEVROLET Z71 TEXAS EDITION TRUCK (A51406)
2020 CHEVROLET Z71...
