Ck2610
   / Ck2610 #1
4020tanner!
Teutopolis
Ck20s
Ok so I got question so I notice to when I had the tractor wide open no load . Rpm over 3k I had little puff of blue smoke. The tractor is turned up around in half. Oil good on safe mark . I normally don't run wide open with no load but today I did. Long I don't max out rpm I never see blue smoke. Even under heavy load no blue smoke. Any idea why
   / Ck2610
I might add the oil level is just little bit over full. In the tractor is turn up a around and a half
   / Ck2610 #4
"In the tractor is turn up a around and a half"
???? What are you trying to say?
   / Ck2610 #5
It's a manual just adjustment of fuel supply. You can theoretically turn the non epa 25hp upto somewhere around 33hp, by removing a crimped cover, and adjusting the screw
Some people say you can get upto 40hp with no ill effect, but im not 100% sure on that
2006 Toyota Highlander SUV (A50324)
2006 Toyota...
John Deere 8430 Track Tractor (A50514)
John Deere 8430...
2013 Mack GU713 T/A Vac-Con Combination Sewer Jetter Vacuum Truck (A50323)
2013 Mack GU713...
Vermeer 840 Discbine (A50774)
Vermeer 840...
