ck2610 smoking
/ ck2610 smoking #1
cowbridge
Slower Lower, Delaware
Kioti CK2610HST Woods BB60XC
Barely a year old, 110 hours. I did the 50 hour maintenance by the book. It starts quickly as is should but coughs and smokes a lot for around 10-20 seconds. It puts out a huge amount of smoke and it's been getting progressively worse. Doesnt matter if its cold or mild out. Seems to operate as normal after it warms up a bit.
Should I be concerned? What should I do to clear this up? It stinks my shop up unbearably every time I start it up
/ ck2610 smoking
No. There was no change at all after the 50 hour service. This issue started in the past month or so
/ ck2610 smoking
No I havent. Does that mean turning the key till the glow plug light goes off, then repeating before starting?
/ ck2610 smoking #6
Sounds like an injector issue.
I would call for service tech to take a look at it.
/ ck2610 smoking
Would using regular diesel fuel and not the red dye off road fuel have anything to do with it?
/ ck2610 smoking #9
Mine smokes pretty good for 10 seconds or so after a cold start. Has always done so.. Just a puff of smoke when it's warm out..
/ ck2610 smoking #10
No. Dye makes no difference. Same fuel one is just charged tax while the other is not. I used dyed (off road) diesel 90 percent of the time. No issues.
/ ck2610 smoking
Its not black. I'd say its between white and grey.
Double cycling the glow plug does help. The first second or two after starting is perfect, but after that it does cough and smoke... but not as bad.
/ ck2610 smoking #13
Mine runs rough if the ambient temps are below 40f.
On yours there is an intake air heater grid that is easily diagnosed. The circuit is controlled by a relay that looks at coolant temperature. If the coolant is below a certain temp the electric grid for the air pre-heater runs for about 30 seconds, you can generally hear the idle speed come up a bit when that circuit for the heater shuts down as the pre-heater uses many amps to heat the intake air.
Check the amp draw at the wire for the grid when first running the engine. Big red wire by the 4 bolt flange on the intake manifold. I'm not sure how many mine draws I can check. Make sure the wire isn't melted by the connector at the pre-heater.
Regards, Fred
2001 Sea Breeze RV (A62613)
2001 Sea Breeze RV...
2016 KUBOTA SVL90 SKID STEER (A65053)
2016 KUBOTA SVL90...
Polaris Sportsman 500 (A64127)
Polaris Sportsman...
Invoices (A65640)
Invoices (A65640)
2005 MACK CV713 MIXER TRUCK (A65643)
2005 MACK CV713...
2020 CATERPILLAR 239D3 SKID STEER (A65053)
2020 CATERPILLAR...
