CK2610 rear blade size?
   / CK2610 rear blade size? #1
tiogajoe
Little Marsh, Pa
Kioti CK2610hst
Can anyone tell me if you can rotate at 6' rear blade on the 2610 without removing from the 3pt? I'm looking at a Bush Hog 50-06. I need the swing offset to clean ditches without getting too close to the edge of the road:eek:
   / CK2610 rear blade size? #2
With a 6' blade I would say yes for sure, but why not get a 7 footer? Your tractor will handle a 7' rear blade fine. With a 7' you need to really check to be sure, my guess is yes the blade can be turned 360* when the boom is straight back. ;)
   / CK2610 rear blade size? #3
Also depends on the blade , I’ve seen some of the cheaper lines that will not turn due to the main beam being short.
   / CK2610 rear blade size? #4
Even with a 6' blade? I know wider than 6' starts to become a problem for the more economical units, but I have never seen a 6' blade that would not turn 360". You would have to have something like a 30" boom and I think that 36" is about the shortest that I've ever seen on any full cat 1 units.
I will have to see if I can get a look at a Bush Hog 50 series blade am measure the beam. I had a 5 footer on my 2510 and could rotate it with no problem.
   / CK2610 rear blade size? #6
I have a 7' woods on my CK25 and I can turn it all the way around. It takes a little "finesse" , but doable. I think a 6' blade is too short.
2023 UNVERFERTH 432 (A53084)
2023 UNVERFERTH...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A51691)
2025 Kivel 48in...
2014 FREIGHTLINER CASCADIA SLEEPER (A54313)
2014 FREIGHTLINER...
UNUSED Metal Garden Arbor Trellis (A53117)
UNUSED Metal...
2019 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A53426)
2019 INTERNATIONAL...
