CK2610 front axle fluid change
   / CK2610 front axle fluid change #12
Summit Racing. Best price on Mobil 424. I really like the 424. Tractor run very quite!
Excellent. Was looking at Summit as well.
Its calling for 90W gear oil or transmission oil. For me I would assume its still 90W
Would be worth a call to the service department. HUGE difference between 90W and UTF.
You Can use either. Mine came with UTF in it. Changed it once at 50 hours and now at 310 hours. No problems. Yes I know manual states to change at 400 hours but I didn't want to do it in Winter Cold weather.
   / CK2610 front axle fluid change #15
That’s fair, I took it to read anything in the row above for acceptable transmission fluid was acceptable.
   / CK2610 front axle fluid change #16
SAE 90 wt or better, or the same as the transmission,
When looking at a spec like that and with the lube going for the differential and bevel and spur drives for the front axle,
personally I would have and have used 75W-140 gear lube as it has better extreme pressure additives (EP).
But it's your axle so do what you wish the manual allows most anything.
   / CK2610 front axle fluid change #17
I have a 2015 CK27. I changed my front axle fluid last year. It uses 90/80 gear oil. Big difference than using UTF hydraulic oil. Your manual states 90/80 w gear oil for front axle. Your HST states UTF hydraulic oil. Do what you think is best. No way i am putting hydraulic oil when it calls for gear oil.
   / CK2610 front axle fluid change #18
I’m new to tractors and happy to learn. Wouldn’t those same stresses be in the transmission and rear end?
   / CK2610 front axle fluid change #19
The differential and planetary reduction in the rear end is usually quite large compared to the front axle,
then you throw the stresses of a front loader on that smaller front axle it is getting heavier loading.
As far as the transmission most of those gears are straight cut gears compared to sliding bevel gears,
also the transmission gears see less torque then do the final drives.
With the hydrostatic transmissions you are back to hydraulic fluid and the large rear end housing makes a convenient reservoir.
   / CK2610 front axle fluid change #20
Information from a kioti manual in regards to gearing and the front axle.
HAMM HD120HV DOUBLE DRUM ROLLER (A52707)
HAMM HD120HV...
2002 Ingersoll Rand P185WIR Towable Air Compressor (A55851)
2002 Ingersoll...
Swict 78" Quick Attach Bucket (A56469)
Swict 78" Quick...
Sakai SV505 Vibratory Roller (A53317)
Sakai SV505...
2016 John Deere 326E (A47477)
2016 John Deere...
2022 Toro Workman 07921 Electric Utility Cart (A54811)
2022 Toro Workman...
