CK2610 front axle fluid change
   / CK2610 front axle fluid change #1
tiogajoe
Little Marsh, Pa
Kioti CK2610hst
Anyone else use more than a gallon of UTF to refill the front axle? I check mine with the dipstick just setting on top of the fill hole. Well over a gallon to get a small amount on the dip stick. I run it with about 1/2" showing on the dip stick when full. I bet I used a least a Gallon and a half of fluid??
   / CK2610 front axle fluid change #2
Manual has it at 1.58 gallons so sounds like you’re spot on
   / CK2610 front axle fluid change #4
Glad I hopped on here to see what was going on. I recently did my first 50 hr maintenance at 72 hours and couldn't believe how much HST oil I used. This post reminded me that my axle is still a little low and need to buy another gallon.
   / CK2610 front axle fluid change #5
No problem. Had the same “where is it going?!?” When I first checked and then topped off the hydro fluid on mine when I first got it. Was about a gallon low 🤦
   / CK2610 front axle fluid change #6
are you sure on the UTF fluid?
My Kioti CK27HST front axle takes 5qts 80W90 gear oil. Never had a 4X4 tractor front axle that takes hydraulic fluid
   / CK2610 front axle fluid change #7
Same here. I bought 2.5 gallons of fluid for my 50 hour service and between the fluid loss when changing the filters, and topping up the front axle, I've only got about half a gallon left.
   / CK2610 front axle fluid change #8
Yep. Per manual
I bought 3 2.5 gallon containers of Mobil 424 to service my 2610. I bet I have under a gallon left.
   / CK2610 front axle fluid change #10
Perfect. That’s my exact plan.
2024 WITZCO RG-52 LOW BOY (A57880)
2024 WITZCO RG-52...
AGT SAII100 SKID STEER QUICK ATTACH 48" (A57193)
AGT SAII100 SKID...
SCAN FOR HAULING AND FINANCING INFORMATION (A54756)
SCAN FOR HAULING...
UNVERFERTH 210 LOT NUMBER 16 (A53084)
UNVERFERTH 210 LOT...
2014 Ford Taurus AWD Sedan (A55853)
2014 Ford Taurus...
2013 BMW X5 xDrive35i AWD SUV (A53424)
2013 BMW X5...
