CK2610 720hours *Updated***
/ CK2610 720hours *Updated*** #22
Yes, I have a Shell Road Runner down the street and get my fuel from there.
Stir your fuel tank with something clean and take a fuel sample from the bottom of your tank into a clear jar and let sit and confirm it isn't contaminated (I just hold my thumb over a clear hose and lift the fuel up and drain it into a jar to do this but turkey basters and big syringes work better).
White vapor is unburnt fuel. On a cold engine at start-up it is normal to see a little white smoke, but not running rough. I'm thinking you have an injector that is leaking or contaminated fuel.
/ CK2610 720hours *Updated*** #23
Well glad you got it to fire up with the new battery. Do you know if the fuel is bio-diesel by chance? (just saw good post above👆) If so, I’d buy non bio from now on. Give ‘er a good workout if possible and then change the oil and filter and see where it goes from there…
I'll give that a try and see what the fuel looks like after sitting in a mason jar for a bit.
I'm not sure if it is Bio-fuel, I don't think it is. I'll be doing a service once I get paid and order the filters, no where local carries then except the dealer and I ain't using them.
/ CK2610 720hours *Updated*** #25
You might find a Wix engine oil filter 51381 (please verify yourself) at an auto parts business, and get a diesel oil at the same place? Acquire the essentials before pulling the plug in the event you have difficulty finding oil. Pm me for a link to order Amsoil online, if that’s an option for you. You can order the Wix and diesel fuel additives at the same time. You will have to contact a Kioti dealer eventually for the HST filters as they’re unique…
I'll send a PM. NAPA has my oil filters, the hydro and fuel I have to source elsewhere. I'll look at Wix, I think the last time I tried them all I could get was oil and air. I'll double check. I don't have an HST, gear machine was the way I went.
/ CK2610 720hours *Updated*** #27
I sent you some links with what I use in my tractor, although I have an HST model…😬
/ CK2610 720hours *Updated*** #28
I used these folks. My tractor is in Michigan and I'm in Florida but everything looks okay to me. Not that it wouldn't be easy for me to miss something, but it looks cool to me. At least you can the part numbers from them and look around. Pricing seems very fair. My Air Filter was a Donaldson which is who makes the OEM AFAIK
/ CK2610 720hours *Updated*** #29
Simple stuff first. Make sure you are getting clean fuel and plenty of it to the fuel pump. Like Eric said get a sample of the tank bottom. That will help. Definitely replace the fuel filter and clean out the bowl. I wouldn't be surprised if you see some water contamination.
Do you guys have winter blend fuel in TN? Seems like TN might be far enough south that its not common, but gets cold enough to gel fuel and cause issues. Fuel quality is suspect too. I treat every gallon that goes in my truck and tractor cause I have had so many fuel issues in the past. I usually buy fuel from a truck stop close by that turns over a lot of fuel. That helps but doesn't eliminate the problems.
/ CK2610 720hours *Updated*** #30
Two things: has all of this been with the same fuel?
I'm thinking it may be time for the injectors to be cleaned.
Interesting comment. Never heard of 'cleaning' injectors, ever. My one M9 has in the excess of 6200 hours on it and other than having them spray tested last year when I had it tuned up at 6000 hours, they have never been touched. Only thing that fails on a diesel injector to my knowledge is the sealing rings or the injector cup or the spray nozzle itself and none of those those have ever failed on my tractors. I get all my fuel from a couple different suppliers, I buy strictly on price and delivery cost. ULSD diesel is the same no matter where you source it. Only thing that is important and that is, you don't get water along with the fuel and most competent suppliers monitor that constantly anyway. I always treat my bulk fuel with a biocide, that is sop with me and Powerservice, white or silver bottle depending on the season.
/ CK2610 720hours *Updated*** #31
If you are going to have to source your Kioti parts/filters online I think Perry Power/Nolts do online sales. I don't do online but I buy at their parts counter and I think their prices are fair. https://www.noltspower.com/
Many people also use Michigan iron & Equip and seem satisfied but I have no experience with them. https://www.michiganironandequip.com/
Keep several fuel filters on hand. They are cheap and can clog suddenly and are a quick simple swap.
/ CK2610 720hours *Updated*** #32
One outfit I don't do business with is Messicks. They are way over the top on ship costs. Found that out the expensive way.
/ CK2610 720hours *Updated*** #33
I bought the spindle to repair my FM from them but they are a 1/2 hour away. And they had the best price. About $125 IIRC and it was a drop-in.
And so I did my shopping in Carlisle that day. They have the best beer store in the area anyhow.
/ CK2610 720hours *Updated*** #34
I'm not and I don't fault their parts prices (though my local Kubota dealer matches or beats them. My complaint is their ship cost. Even Coleman's in Kansas City is less.
/ CK2610 720hours *Updated*** #35
What dealer are you having trouble with? PM me if you don't want to post it.
I can do repairs. I'm in Kingston.
/ CK2610 720hours *Updated*** #36
If you are getting white smoke when it first starts and NOT losing coolant, you might have an injector that is leaking a little.
2016 Chevrolet Silverado 4x4 Crew Cab Pickup Truck (A64194)
2016 Chevrolet...
2022 John Deere 616R Sprayer (A63111)
2022 John Deere...
2016 Jeep Compass SUV (A61574)
2016 Jeep Compass...
2010 INTERNATIONAL PROSTAR PREMIUM ROAD TRACTOR (A63291)
2010 INTERNATIONAL...
2017 Ford Escape SUV (A61574)
2017 Ford Escape...
2002 Suncoast 18ft T/A Enclosed Trailer (A61574)
2002 Suncoast 18ft...
