dfkrug
Super Member
- Joined
- Feb 3, 2004
- Messages
- 7,686
- Location
- Santa Cruz Mtns, CA
- Tractor
- 05 Kioti CK30HST w/ Prairie Dog backhoe, XN08 mini-X
If you have one rear remote set then either pushing or pulling the single
lever will allow flow through the remote valve to your hoe or other attachment, depending on which way the
dealer plumbed the circuit.
Its odd that moving the remote lever in the opposite direction does not make the pump deadhead...
Yeah, the detented remote valve can be set up either way, and if you push the lever in the opposite way
it is supposed to go, you will send oil in the OUT part of the hoe valve, and out the IN part of the valve. When
you operate a hoe valve with the oil flow backwards, and attempt to dig, you will blow out the inner
seals on the hoe valve. The OUT part of the hoe valve can only handle 500psi or so.
This thread is the first I have heard of Kioti (or Bobcat) providing a hoe return-to-reservoir setup, instead of
a hoe return thu the AUX valve. I plan to convert to the better setup this summer when I remove my hoe
for major maintenance.
