CK25 RPM Gauge
   / CK25 RPM Gauge #1
RADDAD50
Sonoma County, Calif
CK25 Gear, year 2006
Does anyone no what runs the RPM gauge on a 2006 CK25, is it cable driven or electrical? Mine has started jumping up and down between o and 10 no mater what the rpms are at.
Thanks
   / CK25 RPM Gauge #2
Yup it's 'lectric. I am not sure if it runs off the alternator or if it is hall effect.
   / CK25 RPM Gauge
Does anyone no where on the flywheel it is located? I looked in the manual and can't really see where it is located.
   / CK25 RPM Gauge #5
Look for a thing with wires coming out of it on the bellhousing.
   / CK25 RPM Gauge #6
At front of motor in area of the injector pump.
Uses cam gear
BTI
   / CK25 RPM Gauge #7
Uses cam gear
BTI
correct bti. look around and below where the injection pump is mounted. on the front cover of engine and there is a black plastic piece with 2 screws holding it in place. wires coming out of it that is your pick up. remove from block, clean pick up, reinstall. check plug where harness plug into sensor, make sure of no corrosion. used dielectric grease to reinstall plug in sensor.
Tony
   / CK25 RPM Gauge
Thanks for the help Lavoie & BTI I will look for it this weekend.:thumbsup:
MASSEY FERGUSON 275 TRACTOR (A58375)
MASSEY FERGUSON...
JOHN DEERE 9570 RX (A58214)
JOHN DEERE 9570 RX...
2016 Chevy caprice (A55788)
2016 Chevy caprice...
SD Launch SDLB25 (A53317)
SD Launch SDLB25...
New Wolverine 78in Skid Steer Land Leveler (A59000)
New Wolverine 78in...
2025 JMR Single Cylinder Grapple Bucket Mini Skid Steer Attachment (A56857)
2025 JMR Single...
