CK25 max hyd. pressure
/ CK25 max hyd. pressure #1
Gittyup
Elite Member
Mid Atlantic
Kioti CK25 Shuttle Shift, loaded tires, JD X739
Does anyone know what is the maximum hydraulic pressure on a CK25? I can't seem to find this number in the specification nor owner's manual.
/ CK25 max hyd. pressure #2
I am not sure what the tractor is rated for, but the operating pressure for the backhoe is 2000 psi, according to a Kioti CK25/30/35 PDF brochure.
/ CK25 max hyd. pressure #3
Hello Gittyup, i believe the pressure range is 2480 to 2560 psi Matt
/ CK25 max hyd. pressure #4
I have a question, whats the easiest way to find out what your hydraulic systems putting out?
Sorry Gittyup, didnt mean to hyjack your thread....chris
Thanks!
/ CK25 max hyd. pressure #6
ALBMN go it. Shop manual says the factory spec fo the relief valve is 2489-2560.
I'd also be interested to know if anyone has an easy way to attach a gage.
/ CK25 max hyd. pressure #7
You can just plumb a gauge into one of the FEL ports, then move the joystick to power that port. You want to dead-head the system right into the gauge. Total cost is about $35.00 or so for the setup.
/ CK25 max hyd. pressure #8
Here's a way of attaching a pressure gauge 'inline', demonstrated on a CK30.
I searched on ebay and found an inexpensive 5000 PSI pressure gauge (about $5.00 + shipping). Took the gauge to a local 'hydraulic hose supply' and asked for a 'T' fitting. They had the exact fitting without having to use any inline adapters, just one reducer for the gauge itself. Cautionary note: Do not use regular plumbling pipe, it's not designed for the high PSI's.
See attachment.
Don
Very cool gauge add-on, TB. Did you use regular pipe thread compound on that connection?
Now that pressure is confirmed, it looks like a 2500 psi cylinder might be damaged by my CK. I guess that means a 3000 psi cylinder.
/ CK25 max hyd. pressure #10
I'm not sure of the exact compund I used. It's been a little while since I added the pressure gauges. Care must be taken if using teflon tape for fear of shearing off a small piece of the tape and then causing problems if it gets jamned in the system. A pipe compound is a more popular choice.
Quick disconnects could be plumbed in the setup for ease of use.
Don
