CK25 engine problem
/ CK25 engine problem
IMG_1252.JPGFinally got into the gear case and the cam gear is a disaster. It is like this all the way around the entire can gear. One tooth is broken the idler gear as well. The crank gear shows noticeable wear from the oil pump.
If anyone has an idea how this could happen, I’d sure like to know so I can avoid similar things in the future.
/ CK25 engine problem #22
WOW.. I don't have an answer but I find it odd that each break has the same shape.. odd indeed..
/ CK25 engine problem #23
Don't just replace those gears; check the front end bearings for damage. Check the shafts for possible fore-aft movement. With luck, the damage will be limited to the gear case (pistons, crank, camshafts, and valves OK). Can't tell the cause but it looks like a gear may have moved (forward or aft) such that all the stress was on the back part of the teeth, breaking off parts of teeth.
KMC 3pt 12 Row Rip Strip Till (A64126)
KMC 3pt 12 Row Rip...
2003 Kenworth W900 L Model (A62613)
2003 Kenworth W900...
20' Reids Trailer (A62613)
20' Reids Trailer...
(16) Kinze 3000 Insecticide Boxes (A65640)
(16) Kinze 3000...
New 20'x20' All Steel Carport (A62679)
New 20'x20' All...
New/Unused Landhonor 16ft x 13ft Metal Carport (A65583)
New/Unused...
