CK25 engine problem
   / CK25 engine problem
They looked curved like a woodruff key only because they broke off that way. The curved part is the break.
Here’s another shot showing the broken edge on 2 and the good side on one.
   / CK25 engine problem #13
I'd stop at a dealer and ask. A mechanic who has had an engine open would know. You say it runs fine. If that was an older style car engine, without overhead cams, I'd say teeth from the crank or camshaft gear. Sorry, I have never had to open my CK30hst engine so not much help.
   / CK25 engine problem #14
Yup. The new and improved picture looks like gear teeth.
One thing I learned long ago: broken mechanical parts don’t heal by running an engine longer.
Also, if one tooth is broken, others are likely damaged and not far behind.
If the gear fails catastrophically and the cam slips out of time, the valves will contact the pistons and likely crack the cylinder walls as part of the ensuing collateral damage.
In the words of Clint Eastwood, do you feel lucky?
Have the dealer do a front end teardown to investigate and replace the broken parts.
   / CK25 engine problem #15
Also, look at the front cover of your tractor and see if the power steering pump or hydraulic pump is gear driven and bolted onto the front cover, or if there are any access hole covers that could be removed for a quick look. The injection pump, for example, should have an access plate for getting at the gear to set timing. A mirror and light would help, as would a scope of some sort.
   / CK25 engine problem #16
Im not made of money, but on something like this I think I would let the dealer fix it
   / CK25 engine problem #17
Have a look here, this is your gear ID on the front of the engine. It may be possible to ID which gear it came from by gauging the tooth length, if you have a tooth piece that is complete, and compare that length to the thickness of each gear (should the dealer have the spare parts to measure, or could acquire the measurements). If they are all different thicknesses, and one of them matches yours, you'll know right where to start scoping, and perhaps save yourself some time.
   / CK25 engine problem #18
i feel your pain. i hope it isnt a major repair. I used to repair alot of car engines with my brother growing up. Back them it was fun. Now days...i have a great and trusted mechanic that i use. Repairing them just wasn't fun anymore.
   / CK25 engine problem #19
I think you really need to inspect the engine gears. As Finn said, it may be catastrophic for the crank and valves to get out of time. You can inspect the big gear on the front of the fuel camshaft by removing the cover plate in front of the injection pump (either the manual stop lever or the speed lever, depending on which version you have). The res of the front gears will likely require opening the rear case to inspect them. In addition to the gears in the gear case (crank. fuel, cam, idler, and oil pump) there are gears on the back end of the fuel camshaft that drive the hydraulic pump. This is a real shame.
   / CK25 engine problem #20
Yes, the front gear case cover needs to be pulled and the gear train inspected. Our concern would be the idler gear that runs the oil pump. If the engine runs with 3 missing teeth from the front gear train, we would be looking closely at the oil pump idler, since the engine would stay in time and run, but possibly without oil pressure.
Don't run the engine without pulling the gear case cover.
Hope this helps.
2001 INTERNATIONAL 4700 4X2 SERVICE TRUCK (A57192)
2001 INTERNATIONAL...
2017 Chevrolet Tahoe SUV (A55853)
2017 Chevrolet...
2000 Morbark Towable Brush Chipper (A55851)
2000 Morbark...
BOSS MT 660 Fuel Trailer - 660 Gallon Mobile Diesel Tank, DOT-Approved (A55315)
BOSS MT 660 Fuel...
2018 DRAGON 150 BBL ALUMINUM TRAILER (A53843)
2018 DRAGON 150...
