CK25 BLOWN HEADGASKET
   / CK25 BLOWN HEADGASKET
How does everyone feel about the retorque of the headbolts after the first 30 minutes of running as the manual says to do ? Seems like an a lot of extra work to take the engine apart again retorque and adjust the valves after only 30 minutes of running ?
   / CK25 BLOWN HEADGASKET #12
I would hope if the manual advises to retorque after 30 minutes, they know what "they" are talking about. The engine has had a chance to warm up and expand. I assume the engine is then allowed to cool down before putting a wrench to the bolts but the manual doesn't make any mention. Checking the valves must mean that the head gasket will crush more. I've never done this with any gas engines but diesels may be different. I'm sure some members will share their experience and knowledge.
   / CK25 BLOWN HEADGASKET #13
Not sure about an engine this small, but on all the diesel and natural gas engines we build, (which is hundreds a year) All of them get a valve adjustment after a 4 hour full power dyno run... They are allowed to cool overnight then get a valve adjustment.
Our engines do not require a re-torque, but if in your manual it calls for one, then yes, you should definitely take the time to do a full retorque.
Kinda makes you wonder if they call for it in the service manual, How do they do it when the tractor was sold new??? Maybe thats whey the Kioti seems to be a little more prone to head gasket failures..
I would still consider doing an annual torque check..
   / CK25 BLOWN HEADGASKET #14
I can't find anything in my manual (DK 35) that says the head bolts need re-torqed.
I'm at 1600+ hours and have never re-torqued the head bolts.
No plans to start messing with them now.
   / CK25 BLOWN HEADGASKET #15
The only place in my Kioti manuals that call for a re-torque of the head bolts is in the service manual when you replace the head gasket for whatever reason. It's not listed anywhere as a routine/scheduled service.
   / CK25 BLOWN HEADGASKET #16
My john deere 450 dozer was rebuilt, and the manual said to retorque. I did not and found out it is stated for a reason. I was blessed with a sudden head gasket failure, and the next time I spent the 2 hrs to retorque. Have not had any more troubles since then. (many hours).
   / CK25 BLOWN HEADGASKET #17
The gaskets fail because of what's called insufficient "gasket margin" area around the cylinder and coolant ports. The width of the gasket material in these areas is minimal. Eventually the 485 psi cylinder pressure erodes a path to the 10 psi coolant port. Engineers try to keep the block compact to save manufacturing cost.
I would replace the head bolts, I believe the torque value in the manual is near the "plastic" range for the bolt material.
The manual does not require re-torqueing and I don't think it is a good idea based on the previous sentence.
   / CK25 BLOWN HEADGASKET #18
A different head gasket may be used when the factory builds the engine than when one does a head gasket replacement- can't say for sure but it is possible. And who's to say the original engine build does not require a retorque?
New head bolts can't hurt, and i would assume they are meant to be installed dry- that is not oiled, because that would change the torque result.
Update: I removed the head and old headgasket. The headgasket had failed at the water port next to #1 cylinder @ gear end of engine. This water port seems to be really close to the cylinder. Everything came apart with no problems but now I'm ready to put everything back together and it says in the service manual to adjust the valves remove the timing check window and turn the flywheel to 1 TC. Well in order to remove the two bolts that hold the window plate in place I have to remove the right side of my FEL and backhoe support bracket which looks like it has about 14/ 3/4" bolts and weighs about 200lbs. I wish Kioti would have cut a hole large enough in the Fel bracket to be able to see this inspection window? So for all you people that want to do a valve adjustment be prepared to remove your FEL and backhoe bracket. :mad:
   / CK25 BLOWN HEADGASKET #20
If you follow the instructions in the manual to set the valves it would require removing the FEL. But you didn't mess with the cam, chain or anything else that would mess up the timing, your just doing a head gasket replacement. To adjust the valves just turn the engine over until the valve spring is unloaded and measure the clearance and adjust to the specs.
2015 CASE 621F WHEEL LOADER (A58214)
2015 CASE 621F...
Unused 2025 CFG Industrial QH12R Mini Excavator (A59228)
Unused 2025 CFG...
(INOP) 2016 CATERPILLAR 259D SKID STEER (A60429)
(INOP) 2016...
30 INCH TOOTHLESS BUCKET FOR MINI EXCAVATOR (A58214)
30 INCH TOOTHLESS...
1999 CHEVROLET C7500 UTILITY TRUCK (A59575)
1999 CHEVROLET...
John Deere 612C Corn Head (A59814)
John Deere 612C...
