CK20S replacement?
/ CK20S replacement? #1
Slackdaddy
Land of the Free
Kioti CK20HST
I know I am missing it somehow? But what designation is Kioti now calling the CK20 platform ??
/ CK20S replacement? #2
I think its would be the Ck2620, which is new 2023, 2022 was the 2610. My understanding is its the same platform as the CK20. I might be wrong thou ???
/ CK20S replacement? #3
Probably the cx2510. A bit smaller than the ck2610. The 2610 would be significantly heavier than your ck20s. Something like 800 lbs maybe?
/ CK20S replacement? #5
Ayuh, the CX2510 is the equivalent machine today; the CK series as it sits is larger than the CK20.
/ CK20S replacement? #6
It ought to be a familiar machine for a CK20 owner, though I don't think the cab was available back then.
/ CK20S replacement? #7
Ck20 then ck2510 and now cx2510. Engine changes, loader changes, hydraulic pump improvements from ck2510 onward, cosmetic minor changes, rear end pretty much the same. From what I've seen first hand.
E.
/ CK20S replacement? #8
I must be reading something wrong, i have been looking at the CK2610 and the dealer said it was replaced with the CK2620, but same machine basically.
Kioti jacked the price up 2k and gave you a new front end look and LED lights.
I was under the impression that the CK10 series is gone and replaced with the CK20, CK2620, 3520 etc.
/ CK20S replacement? #9
I hope I'm reading your post right; the CK20 used to be an individual model, but now is being used to denote the entirety of the new CK line. It's unrelated, but the naming convention isn't the best. Well, the new ones are pretty clear, but they conflict with the old names.
Anyhow, yeah the CK20 series is just an update of the CK10 with a higher price tag, because new and shiny.
/ CK20S replacement? #10
Correct, no more CK2610 unless you can find a left over on a dealer lot. All CH26XX are now CK2620. LED lights, new hood design and 3rd function buttons on the loader control stick. The 3rd function is an add, the wires are there to plug into the valve solenoid. Price increase yes. They were going to increase price no matter new model numbers or not to close gap with the orange competitors model, guess they threw the changes to make us feel good LOL. I just got the CK2620 deliverd Thursday. The increase in cost was expected everything goes up not down. I figure if I am buying new I wanted a 2023 model. The buttons for 3rd functions are handy I must say.
/ CK20S replacement? #11
LOL, there are a few changes to new and shiny CK2620. But everything goes up in cost, look at the price of eggs :):)
/ CK20S replacement? #12
Well, new and shiny causes an increase, the devaluation of the dollar just increased the scale. 🤣😢
/ CK20S replacement? #14
Nice setup MaxLee, I read your other post this morning and was not sure what model you got.
/ CK20S replacement? #15
Thank you fishbone, I tried to get everything in the package for the financing. things I could get are MEI hydro thumb on order and I decided to get the woodmax WM-8M chipper.
/ CK20S replacement? #16
Just to make sure things are clear.. the old ck20 (ck20, ck20s, ck20hst etc) became the ck2510 and now Kioti puts it in its own product line - the cx2510 of which that's the only tractor in that product line. It makes some sort of sense in that previously when it was part of the CK series (ck20, ck25, ck35 etc) it was physically smaller then all the rest in the series and the rest were the same physical tractor being mainly only differentiated by engine power. So now they've removed it from that group and put it on its own. Certainly confusing given they've current model lines called ck20 - which is the larger platform.
Hope that helps! Lol.
E.
/ CK20S replacement? #18
E.
LOL, damn Korean can't keep anything simple.
Kioti, the Abbot and Costello of tractors. 💜
I will say this CK2620 is a beast so far, haven't done a whole lot but it seems stout. Could be cause I am coming from the CS2410 lol. I looked back at some post from 2013 and guys told me to get a bigger then I need tractor, well 10 yrs later I think I listen to them
