CK20s
/ CK20s #1
akw1700
Ford
I have a Kioti CK20s the rear PTO buzzes connected to the bush hog attachment when the clutch is pressed. Can anyone give me some advice for the fix. Maybe a clutch adjustment. Thanks!
/ CK20s #2
That's normal. The ck20 has an over run clutch internal on the pto that makes that ratcheting sound when you press the clutch in - this allows whatever is connected to continue to spin down until it stops, otherwise a spinning implement attached to the pto would drive the tractor forward until it stops spinning.
E.
