CK20 shuttle ?
/ CK20 shuttle ? #1
Slackdaddy
Land of the Free
Kioti CK20HST
Is the CK20 available with a Shuttle ?
or only traditional manual or Hydrostatic ?
Thanks,
Nick
/ CK20 shuttle ? #2
I was looking at these a while back and pretty sure a shuttle is not available.
/ CK20 shuttle ? #3
The CK20S Does not have a true shuttle.
1st and reverse are opposite of each other and those 2 gears are synchronized.
So if you are doing something in high or low range and you are in 1st you can push in the clutch and pull it into reverse and you will not grind the gears.
But as far as having a true shuttle with every gear having a forward and reverse, this model does not.
You have to move up to a CK25 or switch to a hydro CK20S.
BTI
