Ck20 s cab
/ Ck20 s cab #1
Kioti guy
Severn Bridge Ontario
2011 kioti ck 20S Hst,Case D
I was just wondering if anyone has one of the new kioti compact cabs on there ck20? I have been thinking seriously about getting one before the winter snow blowing season. ( i know its early to worry about snow but i'm allready sick of the heat..lol)
/ Ck20 s cab #2
I don't have one yet:( but i've been in one, got pics of a CK20S and CK30 with the Kioti Kab if you want better ones than the ones on the site. The only down side of the cab, is that the rear side windows don't tilt out (like on the DK series), no A/C kit yet. But it's a very nice cab, fit and finish is like it came from the factory:thumbsup: Hope this helps
KK
/ Ck20 s cab #3
Here are some pics of a CK20S HST with kioti kab
/ Ck20 s cab
Thank's for the info karl, i would really like to see the pictures,maybe you could post them to the thread?
It's to bad that A/C isn't available, that would maybe make the heat a little more bearable. .....Craig
/ Ck20 s cab #6
Boy, that Kioti cab makes my Sims cab look home-made. :cool:
Very nice! :thumbsup:
/ Ck20 s cab #7
That's one good looking tractor:thumbsup:, just love my Kioti tractors.:D
/ Ck20 s cab #8
Maybe the sims cab isn't as finished as the Kioti cab, but you get 2 sims cabs for the price of one Kioti cab:laughing:
/ Ck20 s cab #9
I test drove a CK20 with cab this weekend and really liked it. I'm looking at the CK30 but the dealer didnt have one with a cab set up. Inside the cab is nice, but for the lack of A/C. However I like that Kioti accept that people would like a radio, I dont think they offer a installed radio.... BUT they have filler panels over the stereo and speaker areas AND the harness is already there... that makes installation easy!
My main gripe with the Compact Cab is that it doesnt have an option for a rear wiper. That's something I would like if I am going to be doing snow removal
/ Ck20 s cab #10
Maybe even 4 Sims cabs for what I paid for it back in 2005. :D
/ Ck20 s cab #11
How do you use the rear snow blower with the back window on? Is the chute controlled remotely? On my Meteor, I have to manually crank the chute around, so I would need the back window off or wide open.
/ Ck20 s cab #12
My chute is manually operated as well. Luckily, my driveway is pretty straight so I turn it to one side and make a long pass. Then get out and turn it to the other side, turn the tractor around and make another long pass back down the drive. About 4-5 passes depending on snow depth and it's done. One of these days, I would love to setup a chute adjuster via an electric motor or hydraulically driven from the rear remotes.
/ Ck20 s cab #13
Yes, the rear remotes are just hanging there in the winter so someone should be able to design a chute rotator that works off of them. Good project for Michigan Iron. Probably end up with a $500 solution to a $2 problem but hey getting in and out of the tractor in the winter is no fun. Maybe just take the back window out.
/ Ck20 s cab #14
Lucky for me, i don't get off the tractor to operate the chute:D
/ Ck20 s cab #16
KiotiKarl, just curious, but what did that system cost??? It is neat, no doubt about it.
I do not need the hydraulics to maneuver for distance, but being able to rotate the chute from the cab would be nice. Is that part electric rather than hydraulic?
/ Ck20 s cab #17
All the new KIOTI Kabs will have the option of rear wiper.:thumbsup: And witht he KIOTI Kab you can just open the rear window to adjust you manual chute if the crank is long enough.:D And yes it is more expensive than the Sims, but the fit, finish of the exterior and interior are far greater than any other brand out there.:cool: Price is always a factor with everything, if it wasn't you would have bought a cab tractor when you were first buying, I myself love the KIOTI Kab and it is one of the most quietest and spacious with the factory finish and not some back yard bill look.
/ Ck20 s cab #18
The chute turns via a hydraulic ''orbit'' motor, and a double acting cylindre for the chute distance. Works off the rear remotes. The hydraulic vs manual operation was 400$cdn when i purchased the blower. I don't know if the turn can be a later add on. There are cheaper hydraulic turn model which work with a cable/cylindre combo. I will post better pics later.
/ Ck20 s cab #19
Here are the pics of the hydraulic chute i was talking about, also the last pics of my DK45SEC, i feel kinda sad knowing it's sold:( and i have to deliver it tomorrow.
/ Ck20 s cab #20
That is a sweet cab. Can it be added after purchase?? Would it work on the equal bobcat tractor??(122.)
40ft High Cube Shipping Container (A64553)
40ft High Cube...
Altec Digger Derrick Hydraulic Boom (A61572)
Altec Digger...
Kivel Quick Hitch Mini Skid Steer Attachment (A64553)
Kivel Quick Hitch...
Aluminum Bear (A65583)
2013 Honda 250 Recon ES ATV (A64557)
2013 Honda 250...
Landhonor 3-Pt PTO Potato Harvester (A66285)
Landhonor 3-Pt PTO...
