CK20 regrets ?
/ CK20 regrets ? #1
Slackdaddy
Land of the Free
Kioti CK20HST
Looking hard at the CK20HST (bobcat CT120), I would have one if it had 3 range trans, had a good integrated backhoe mount (Kub 2x20 series).
Does anyone who has bought a CK20HST:
1) find the 2 speed trans a "regret" or show stopper ?
2) Has anyone put another backhoe on, that has a better designed sub
frame ?
Thanks,
Slack
/ CK20 regrets ? #2
I loved my CK20. However, if I had to identify one thing to change it would have been the 2 speed HST. I ended up doing almost all work including mowing in low range. The new Kubota B series with its 3 range HST will surely cause Kioti to upgrade as well. I rarely needed to take the CK20 on the road and would happily have traded top speed for a midrange level gearing on the HST.
I did not find any problem with the KB2365 subframe. It mounted easily and I never had trouble with clearance. I have a Woods 4pt BH on my new tractor and frankly it takes longer to hook that up than the KB2365.
/ CK20 regrets ? #3
No regrets, then again I am on flat ground. I mow in high gearand even do some loader work in high gear. It'll bog down much more than in low but it'll still get 1/2 buck full of dirt using high range. Would I trade the high range for a medium range? Yes, but to me it's not a show stopper.
/ CK20 regrets ? #4
I think that things will be way different now that the CK20S is out it does not even feel like the old CK20.
As for your backhoe question...
I have used the Rhino 65a(same as Bobcat), the Woods 6000, the Woods 70X and also the Kioti 2365 and 2465
The best mount up I had found is the Woods 70X.
/ CK20 regrets ? #5
Or move up to the CK25 HST and you'll have 3 ranges.
/ CK20 regrets ? #6
I just bought a 2008 CK20S HST. I had never driven an older CK20 but high range could be a bit lower but I don"t have any trouble coming up my driveway in high. The tractor has lots of power and since I live on a hill, no flat ground to mow, I will probably mow in low range. Don't really mind though it gives me more seat time on the tractor. I researched all brands of tractors they sell in this area and I'm very happy with my Kioti.
/ CK20 regrets ? #7
2-1/2 yrs later and over 320hrs, no regrets here. I have done quite a bit of work in high gear including hills and loader work (mostly backblading). I run it at about 2800rpms when doing loader work or anything in high gear and about 2400rpms in low gear for any work.
The backhoe is off in less than 2 minutes and on in about 5 or 6. It's incredibly strong and has a good reach for its size. I have the 16" bucket and feel it is a perfect match. I know I wouldn't trade it for a thing...:cool:
MOBILE HOUSE SKID (A63569)
MOBILE HOUSE SKID...
2018 HINO SA (A58214)
2016 John Deer 5075E (A60462)
2016 John Deer...
1997 Capacity Spotter Truck (A62679)
1997 Capacity...
2011 WESTERN STAR  4900 SB (A63569)
2011 WESTERN STAR...
2022 Belshe WB14 18ft Trailer (A64047)
2022 Belshe WB14...
