CK20 HST Filters
   / CK20 HST Filters #11
Yeah, that's a guess. If I buy a filter, that filter needs say it is made for my tractor. Not a Xref of a Xref. If it fails, I can then go to NAPA and say it failed and you said it would work.
It might be fine, but then again, it might not. Good to know the dealer anyway and on the CK30 it is the low hanging hydro filter that is super expensive. The one that doesn't have an aftermarket. All others are pretty cheap and I can visit/support my tractor dealer.
   / CK20 HST Filters #12
I just had a guy burn his engine up on a ck20..... napa sold him the wrong filter and he didn't notice it leaking.
Think the local napa store will buy him a new engine? I doubt it.
   / CK20 HST Filters #13
Would Kioti buy you a new engine because a bad filter? Try proving that one. If the guy didn't check for leaks after install that's on him in my book. If you took the NAPA filter and the Kioti filter painted them both gray and held them side by side you would be able to tell which is which would not surprise me if they came off the same assembly line with different names. I might be more inclined to go to the dealer if I had one as close as Highbeam does. I bought my backhoe from that dealer, it's a two and a half hour drive for me, that's a lot of diesel in my pickup.
   / CK20 HST Filters #14
I use a Baldwin B260-10 on my HST.
   / CK20 HST Filters #15
New choice for the ck20 hst filter is to use the
ck 25/30/35 hst filter, It is about 1/3 the cost.
That is info given right from the kioti parts department.
   / CK20 HST Filters #16
Looks like you guys have beat this to death but after about two hours of looking at this forum and doing searchs, I still don't see where anyone really said what the Kioti OEM, Trans and oil filter part numbers are and if there are suitable aftermarket replacements. Does anyone know this information for the CK20S?
   / CK20 HST Filters #17
Oil filter wise, I know the Wix 51334 is good. Which Kioti models/engines it's for is even listed on the Wix website.
   / CK20 HST Filters #18
I thought it was #1324. Just be sure to verify application when not using OEM.
   / CK20 HST Filters #19
Gday all
Don't know if this is correct for USA but CK20 hst filter # for Australia is T2360-38031
Cheers
Allan
(greengrasshoper) spelt my way
CK35 HST
Club Car Carryall 2 Electric Utility Cart (A55853)
Club Car Carryall...
2023 Unverferth 3PT 6 FT Perfecta Field Cultivator (A56436)
2023 Unverferth...
Krause Dominator 4850-18ft (A56435)
Krause Dominator...
CRAFTSMAN TABLE SAW (A54757)
CRAFTSMAN TABLE...
ELECTRIC GOLF CART (A58214)
ELECTRIC GOLF CART...
2015 Peterbilt 389 Sleeper Cab Truck Tractor (A55973)
2015 Peterbilt 389...
