CK20 Gear (Grinds when shifting)
   / CK20 Gear (Grinds when shifting) #1
project
Northern CA
Checked out a new CK20 gear yesterday. When the dealer took it out, it was grinding with every shift while on the go. He said this was normal. I tried it and the same thing happened. Was off in a hurry. I tried the 1914 and the CK25 (both gear) they were both very smooth. Any experience out there on the CK20 shifting. I'm assuming you must come to a stop before shifting. I did ask the question prior to testing and was told to shift on the go.
   / CK20 Gear (Grinds when shifting) #2
CK 20 gear is the only model that is not sychronized. 1st and reverse is sychronized on this model but not 1-2-3. You MUST come to a stop. The other models are all sychronized 1-2-3-4 and the shuttle.
LB1914 and LK3054 are non-synchronized shuttles also.
KO
   / CK20 Gear (Grinds when shifting) #3
Please call you dealer and tell him to learn a little about his equipment. Shift on the go in a non-synchro gear? The grinding should have told him not to do that.
John
   / CK20 Gear (Grinds when shifting) #4
If the dealer didn't know that you had to stop when you shift, which should be basic knowledge to the dealer, then you might consider another Kioti dealer. He is supposed to be able to show/explain the basic operations of the tractors to the people who buy them. How's he going to explain something more complicated?
   / CK20 Gear (Grinds when shifting) #5
</font><font color="blue" class="small">( How's he going to explain something more complicated?
)</font>
Hey Victor. Now you know that that IS the most complicated thing about a CK20 gear, the shifting! LOL /forums/images/graemlins/grin.gif
John
   / CK20 Gear (Grinds when shifting) #6
John,
I dont' know that the CK20 was a non-synchro. Is any of the other Kiotis 40 hp or under non-synchro?
   / CK20 Gear (Grinds when shifting) #7
nope..... the CK20 is the lone one..... i have no idea why they did not put a shuttle in it....
   / CK20 Gear (Grinds when shifting) #8
Thanks Jon. I had always assumed and you know what happens when you assume, that they were all Synchro. If they did put a shuttle on the CK20, it would make a really good tractor even better.
   / CK20 Gear (Grinds when shifting) #9
Jerry it's just synched between reverse and first.
I'm surprised they didn't make it like the other models with synchronized main gears.
Also, the shuttle on the 1914 is not synchronized, but manual.
John
   / CK20 Gear (Grinds when shifting) #10
Thanks John. The way they are going, they will more than likely change it at the next complete update.
2009 Peterbilt 384 T/A Wet Kit Day Cab Truck Tactor (A50323)
2009 Peterbilt 384...
2016 FORD EXPLORER (A51406)
2016 FORD EXPLORER...
2019 CATERPILLAR 259D SKID STEER (A51242)
2019 CATERPILLAR...
2016 Ford F-150 Ext. Cab Pickup Truck (A50323)
2016 Ford F-150...
2006 TRAIL MASTER  DETROIT-TRIPLEX PUMP TRAILER (A50854)
2006 TRAIL MASTER...
2019 John Deere 8295R MFWD Tractor (A50657)
2019 John Deere...
