CK20 Gear (Grinds when shifting)
   / CK20 Gear (Grinds when shifting)
thanks for clearing up the shifting on the CK20. I'll be in touch with this dealer shortly. If I decide on this tractor, I'll be sure to buy one from the warehouse. Just to be clear on the 1914.Must you stop before shifting?? It did shift like it was synchro. Thanks
   / CK20 Gear (Grinds when shifting) #12
the main gears on the LB1914 are syncro..... you can shift on the go by clutching.... however when you use the shuttle you must be at a stop....
Just pick up some brochures for the CK20 and the LB1914. the CK20 (gear) reads Synchro/Constant. LB1914 reads Full Synchomesh w/ Mechanical Shuttle. All of this means What?? Thanks to all that replied.
   / CK20 Gear (Grinds when shifting) #14
........ but if you have a REALLY fast left leg and arm you could do the 'ol "double clutch" thing /forums/images/graemlins/smirk.gif. I only got it to work a couple of times when I owned my CK20 gear and that was on a down hill where the tractor wouldn't lose speed, could never do it on flat ground /forums/images/graemlins/mad.gif
Jon, can you explain how the mechanical shuttle shift works on the LB1914. (instead of asking dealer) thanks
KUBOTA U55-5 EXCAVATOR (A51242)
KUBOTA U55-5...
UNUSED CFG Industrial MX12RX Mini Excavator (A47384)
UNUSED CFG...
2017 Ford F-550 Ext. Cab Valve Maintenance Truck (A50323)
2017 Ford F-550...
Kinze 840 Grain Cart (A50514)
Kinze 840 Grain...
2017 Claas Jaguar 860 Forage Harvester (A52128)
2017 Claas Jaguar...
2017 Ford F-250 4x4 Knapheide Service Truck (A50323)
2017 Ford F-250...
