ck20 engine will not shut down with key
/ ck20 engine will not shut down with key #1
jimb1724
Claremont, NH
ck20hst
greetings all.... its been a while since my last post but i have been checking in from time to time.... well i've only managed to put 38 hrs on since april delivery..... but still 38 hrs of fun...... only problem with the ck20h is that the ignition key will NOT shut down the engine. /forums/images/graemlins/mad.gif.... have to use the emergency pull..... my service guys have taken a look but no luck fixing it yet.... has anyone else had this problem ?
/ ck20 engine will not shut down with key #2
Never seen it happen before but it sounds like the engine stop solenoid or one of the components that trigger its not working. Shouldn't be hard of a fix. I would just start at the solenoid and work my way back from there.
/ ck20 engine will not shut down with key #3
No, hasn't happened to me, or anyone I know of. Like Jon said, the solenoid is probably not working correctly. Did they try a different switch to eliminate that as a cause?
Good luck, shouldn't be a major deal. John
EDIT: I'd keep my eye on the battery to make sure everything is really off as well until you get this repaired. J
/ ck20 engine will not shut down with key #4
One of ours on the lot wouldn't shut down either. The wire was unplugged. /forums/images/graemlins/tongue.gif
KO
2022 Mack Pinnacle T/A Day Cab Truck Tractor (A64556)
2022 Mack Pinnacle...
2010 Kia Soul SUV (A66738)
2010 Kia Soul SUV...
2006 PETERBILT 379 TRI-AXLE (INOPERABLE) (A67714)
2006 PETERBILT 379...
MINI ROCK GRAPPLE (A61572)
MINI ROCK GRAPPLE...
2007 Freightliner M2 106 Pothole Patcher Truck (A66736)
2007 Freightliner...
2019 INTERNATIONAL DURASTAR 4300 REEFER TRUCK (A67714)
2019 INTERNATIONAL...
