CK20 cracked FEL
   / CK20 cracked FEL #31
I bought a whole new assembly for mine. So now I have both styles. I will grab a pic of both in the next couple days.(kinda busy now) and post them here.
   / CK20 cracked FEL #32
on my kubota the torque tube is round and hollow right behind the quick attach on the loader arms
   / CK20 cracked FEL #33
Pray tell, why did you buy a new loader?
   / CK20 cracked FEL #34
Is the torque tube (the connecting piece about three feet behind the bucket that holds the left and right side of the loader together) round and hollow or is it a closed box? Almost certainly you have the round tube version as the original version has not been manufactured for about five years now.
Thanks - looks like I'm good. On the actual sticker on the loader it says it's a KL120P.
It's round and hollow but also has a cover.
   / CK20 cracked FEL #35
Mine flexed like a snake and the pistons were all worn out needing packing. The prior owner didn't own a grease gun it appears. The new one was a take off of another machine that the owner didn't want. I got it at a good deal.
Still no pics. Didn't make it to the garage yet for but will today after work.
   / CK20 cracked FEL #36
That is remarkable. Glad you found a replacement at a good price. I would imagine the older worn loader is still worth $$$$ so don't scrap it.
Replacing the cylinders would be an interesting project with a steep learning curve. I watched an expert do a demo once which was interesting and demystified the process. The parts are cheap and having seen it done, it appears not to require finesse so much as a feel for when and how to apply brute force. A big vice is the only must have piece of equipment. The first one would take a while but the other three would be much easier. I'm sure people on TBN have done it themselves and could provide advice.
   / CK20 cracked FEL #37
i seen it done on a 580b case backhoe that was 25 yrs ago i was 9 i think
   / CK20 cracked FEL #38
I've rebuilt a few when working at my dad's garage when I was younger. We fixed all types of trucks and tractors.
Pics as promised.
Old style (2006-2008) This has a rear access panel bolted on.
back view
front view
side view
   / CK20 cracked FEL #39
New style or 2011 model. This has a wrap around cover front to back.
back
front
side
Hope this helps.
   / CK20 cracked FEL #40
Pics as promised.
Old style (2006-2008) first:
back viewView attachment 301336
front viewView attachment 301337
side viewView attachment 301338
I see grease coming out of those joints. Was that only after you got the tractor? Are the bushings also in need of replacement? That would seem to be a much bigger job than just repacking the cylinders.
378810 (A51572)
378810 (A51572)
Deutz 2WD 53HP Utility Tractor (A51691)
Deutz 2WD 53HP...
JCB 525-60T4 5,500lb 4x4 Rough Terrain Telehandler (A51691)
JCB 525-60T4...
New Holland B95 Backhoe (A50490)
New Holland B95...
2017 FREIGHTLINER M2 BOX TRUCK (A52141)
2017 FREIGHTLINER...
LATE MODEL JOHN DEERE EQUIPMENT AUCTION (A53084)
LATE MODEL JOHN...
