CK20 cracked FEL
   / CK20 cracked FEL #31
I bought a whole new assembly for mine. So now I have both styles. I will grab a pic of both in the next couple days.(kinda busy now) and post them here.
   / CK20 cracked FEL #32
on my kubota the torque tube is round and hollow right behind the quick attach on the loader arms
   / CK20 cracked FEL #33
Pray tell, why did you buy a new loader?
   / CK20 cracked FEL #34
Is the torque tube (the connecting piece about three feet behind the bucket that holds the left and right side of the loader together) round and hollow or is it a closed box? Almost certainly you have the round tube version as the original version has not been manufactured for about five years now.
Thanks - looks like I'm good. On the actual sticker on the loader it says it's a KL120P.
It's round and hollow but also has a cover.
   / CK20 cracked FEL #35
Mine flexed like a snake and the pistons were all worn out needing packing. The prior owner didn't own a grease gun it appears. The new one was a take off of another machine that the owner didn't want. I got it at a good deal.
Still no pics. Didn't make it to the garage yet for but will today after work.
   / CK20 cracked FEL #36
That is remarkable. Glad you found a replacement at a good price. I would imagine the older worn loader is still worth $$$$ so don't scrap it.
Replacing the cylinders would be an interesting project with a steep learning curve. I watched an expert do a demo once which was interesting and demystified the process. The parts are cheap and having seen it done, it appears not to require finesse so much as a feel for when and how to apply brute force. A big vice is the only must have piece of equipment. The first one would take a while but the other three would be much easier. I'm sure people on TBN have done it themselves and could provide advice.
   / CK20 cracked FEL #37
i seen it done on a 580b case backhoe that was 25 yrs ago i was 9 i think
   / CK20 cracked FEL #38
I've rebuilt a few when working at my dad's garage when I was younger. We fixed all types of trucks and tractors.
Pics as promised.
Old style (2006-2008) This has a rear access panel bolted on.
back view
front view
side view
   / CK20 cracked FEL #39
New style or 2011 model. This has a wrap around cover front to back.
back
front
side
Hope this helps.
   / CK20 cracked FEL #40
Pics as promised.
Old style (2006-2008) first:
back viewView attachment 301336
front viewView attachment 301337
side viewView attachment 301338
I see grease coming out of those joints. Was that only after you got the tractor? Are the bushings also in need of replacement? That would seem to be a much bigger job than just repacking the cylinders.
Bucket Truck (A55973)
2020 Bobcat MT85 (A53317)
2020 Bobcat MT85...
New Bolt on Receiver (A59000)
New Bolt on...
JCB 2145 (A47477)
JCB 2145 (A47477)
Armstrong 64-405A Torque Wrench (A59076)
Armstrong 64-405A...
Case-IH 160 Puma (A57148)
Case-IH 160 Puma...
