CK20 Coolant Leak
   / CK20 Coolant Leak #1
Sandlot
CA. High Desert
Kioti CK20(Gear)
I started noticing a stain on the concrete floor under my little toy. Taking a look under the engine, I found coolant on the frame. Doing a bit more looking, I found that it is coming from the right side of the engine where the coolant line attaches to the block. This fitting appears to screw into the block; it has flats for a wrench or socket. Before I start wrenching on it, I need to know if it is screwed in and or pressed in. I know it has flats on it but..... Has anyone else had a problem with this fitting? :confused:
   / CK20 Coolant Leak
OK, I'm putting a wrench to this sucker in the morning. I was hoping to hear from a dealer on whether this is a good idea or not. I had thought about just adding some radiator sealant, but I hate the stuff. Anywho, somebody stop me before I screw up my engine block! :eek:
   / CK20 Coolant Leak #3
Make sure and check the hose clamps. I had some leaks on my CK20S last winter that was running along several things. I finally found the source on one of the radiator hoses where there is a hard line in between 2 rubber hoses. The leak was at one of the connections between the rubber line and the hard line. The hose clamps were painted, but aside from getting a socket in there, it turned fairly easily and that was all it took to stop the leak.
   / CK20 Coolant Leak
Novi,
I will double check in the morning, but it looks like it is coming from the engine block side of the adapter. I didn't get to it today, had a honey do, but will be at it tomorrow.
Thanks!
   / CK20 Coolant Leak
Well after draining the coolant and removing the hose, I was unable to budge that fitting screwed into the block. I did not want to use a cheater bar and break something, so I will give some prestone stop leak a try. Oh well, it was due for a coolant change.
New/Unused CFG Industrial H15R Mini Excavator (A57453)
New/Unused CFG...
2007 STERLING TRUCK L9500 CHEMICAL TRANSPORT TRUCK (A58214)
2007 STERLING...
Universal Mount Equipment Seat W/ Headrest & Arm Rests, and Seat Belt (New/Unused) (A59225)
Universal Mount...
New/Unused Electric Golf Cart (A57453)
New/Unused...
2007 Godwin Pumps GHP45KW-RC 45kW Towable Diesel Generator (A56857)
2007 Godwin Pumps...
22018 (A56859)
22018 (A56859)
