CK20 Coolant Leak
   / CK20 Coolant Leak #1
Sandlot
CA. High Desert
Kioti CK20(Gear)
I started noticing a stain on the concrete floor under my little toy. Taking a look under the engine, I found coolant on the frame. Doing a bit more looking, I found that it is coming from the right side of the engine where the coolant line attaches to the block. This fitting appears to screw into the block; it has flats for a wrench or socket. Before I start wrenching on it, I need to know if it is screwed in and or pressed in. I know it has flats on it but..... Has anyone else had a problem with this fitting? :confused:
   / CK20 Coolant Leak
OK, I'm putting a wrench to this sucker in the morning. I was hoping to hear from a dealer on whether this is a good idea or not. I had thought about just adding some radiator sealant, but I hate the stuff. Anywho, somebody stop me before I screw up my engine block! :eek:
   / CK20 Coolant Leak #3
Make sure and check the hose clamps. I had some leaks on my CK20S last winter that was running along several things. I finally found the source on one of the radiator hoses where there is a hard line in between 2 rubber hoses. The leak was at one of the connections between the rubber line and the hard line. The hose clamps were painted, but aside from getting a socket in there, it turned fairly easily and that was all it took to stop the leak.
   / CK20 Coolant Leak
Novi,
I will double check in the morning, but it looks like it is coming from the engine block side of the adapter. I didn't get to it today, had a honey do, but will be at it tomorrow.
Thanks!
   / CK20 Coolant Leak
Well after draining the coolant and removing the hose, I was unable to budge that fitting screwed into the block. I did not want to use a cheater bar and break something, so I will give some prestone stop leak a try. Oh well, it was due for a coolant change.
John Deere 850 Tractor (AS IS) (A50774)
John Deere 850...
2013 VOLVO VNM TANDEM AXLE DAY CAB (A52141)
2013 VOLVO VNM...
2021 John Deere 333G Compact Track Loader, 390 Hours, High Flow Hydraulics, Ride Control (A52748)
2021 John Deere...
2011 Chevrolet Avalanche LTZ Crew Cab Pickup Truck (A50323)
2011 Chevrolet...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52748)
80in HD Tooth...
2014 Ford Fusion SE Sedan (A50324)
2014 Ford Fusion...
