CK20 BH problem
/ CK20 BH problem #1
KenGod
PA
CK2610HST
I just got my BH for my ck20. I used its once and it was fine. Today I took it out to dig a trench when I noticed that the left movement joystick does not have the spring return to neutral, up/down/right still has the spring return to neutral but left stays where you leave it. I know they will cover it under warranty, but I was wondering if anyone else had this problem? What baffles me is that from the time i put it away after the first use and today something happened to it and no one has touched it. maybe I have a spring thief in my area, lol, crazy stuff
Ken
/ CK20 BH problem #2
Sounds like it needs a little lubrication on the linkage.
/ CK20 BH problem
It doesn't feel like a sticky linkage, it feels loose, easy to move just no spring tension.
/ CK20 BH problem #4
Take off the cover so that you can see what is going on. There are pivots that the linkage turns on, they may have a bolt loose or out.You should be able to tell quickly after the cover is off.
iDrive TDS-2010H...
H&S V-12 Rake (A63688)
2012 Ford F-150 Harley-Davidson Edition - 48k miles (A63689)
2012 Ford F-150...
New 5/16" G80 Double Chain Sling (A62679)
New 5/16" G80...
UNVERFERTH HT25 HEADER CART (A63291)
UNVERFERTH HT25...
2019 Ford F-150XL (A60462)
2019 Ford F-150XL...
