CK 30HST Cab wiring schematic - fan problem
/ CK 30HST Cab wiring schematic - fan problem #1
Retired guy
Bronze Member
Western, ME
CK 30HST
Does anyone out there have the wiring diagram for a 2012 CK30 cab. My dealer does not even have it in the shop.
My heater fan only runs on low. The original 2 way switch showed continuity in both positions but I bought and
installed a new one - same results. I am looking to see if there is a hidden relay or separate fuse for high speed.
I suspected the resistor but it is the low speed that is working. Suggestions?
/ CK 30HST Cab wiring schematic - fan problem #2
Try this one
  • Kioti CK25 30 35 Electrical Schematic.pdf
/ CK 30HST Cab wiring schematic - fan problem #4
Here's the one for the Field option cab
  • FieldKabCK20S-CK35-ElectricalSchematic.pdf
That's the one. Thank you. In your experience as a dealer, any thoughts on the problem?
/ CK 30HST Cab wiring schematic - fan problem #7
Honestly not sure, without actually testing it. I can't say that we've ever encountered that problem at our shop before.
/ CK 30HST Cab wiring schematic - fan problem #8
judging by that diagram, i suspect a bad relay OR a bad inline resistor (low speed ). would have to pull it to test though. and if i was going to go thru all that hassle, id just replace the parts, but thats just me. just getting to the parts will suck, at least on my DK45. been up there 2 times, not fun.
Had an hour today, took the roof off, traced the blue wire with the white tracer from the motor to a relay
and replaced it. Problem solved thank you perrypower for the schematic.
2022 CATERPILLAR 289D3 SKID STEER (A65053)
2022 CATERPILLAR...
E-Z Trail 300-bushel Gravity Wagon (A66408)
E-Z Trail...
Tow arm attachment (A64194)
Tow arm attachment...
Thorp Stainless Steel Feeder (A65640)
Thorp Stainless...
8x8 Meyer X1206 Farm Wagon (A65579)
8x8 Meyer X1206...
2022 EZ-GO ELITE...
