Ck. 3054 won't turn over
   / Ck. 3054 won't turn over #1
moondawg
Kioti 3054
Had not used my tractor for couple of weeks and went start up to mow and turned the key to the left to warm the glow plugs and turn right and it clicked a few times and then nothing. Waited a few minutes and tried again and nothing at all. Any ideas of what try or where to start trouble shooting greatly appreciated.
   / Ck. 3054 won't turn over #2
Start with the battery post. Make sure they are tight and clean. If you have a meter check the voltage. Maybe try jump starting.
   / Ck. 3054 won't turn over #3
Start at the battery. What is the battery voltage? What is the battery vpltage as someone turns the key to glow and then to crank?
Symptoms resemble dead battery or bad battery cable.
2007 Homemade Pipe Trailer (A55973)
2007 Homemade Pipe...
2017 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A58017)
2017 FREIGHTLINER...
2022 Polaris Ranger 900XP 4x4 Utility Cart (A55853)
2022 Polaris...
2006 Toyota 7FGU60 11,250lb Propane Forklift (A55973)
2006 Toyota 7FGU60...
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Terex LT40 Boom (A56435)
2016 RAM 5500...
2023 Kubota LX2610SUHSD MFWD Compact Tractor with LA535 Front Loader (A56435)
2023 Kubota...
