Ck. 3054 won't turn over
   / Ck. 3054 won't turn over #1
moondawg
Kioti 3054
Had not used my tractor for couple of weeks and went start up to mow and turned the key to the left to warm the glow plugs and turn right and it clicked a few times and then nothing. Waited a few minutes and tried again and nothing at all. Any ideas of what try or where to start trouble shooting greatly appreciated.
   / Ck. 3054 won't turn over #2
Start with the battery post. Make sure they are tight and clean. If you have a meter check the voltage. Maybe try jump starting.
   / Ck. 3054 won't turn over #3
Start at the battery. What is the battery voltage? What is the battery vpltage as someone turns the key to glow and then to crank?
Symptoms resemble dead battery or bad battery cable.
Toro MBTX-2500 Concrete Buggy (A54865)
Toro MBTX-2500...
Toro Multi Pro 5800 (A55758)
Toro Multi Pro...
1000 Gallon Supply Tank (A53314)
1000 Gallon Supply...
2004 MACK CV713 MIXER TRUCK (A55745)
2004 MACK CV713...
2014 Ford Explorer SUV (A56859)
2014 Ford Explorer...
30pc 3ft. x 8ft. Red Polycarbonate panels (A55758)
30pc 3ft. x 8ft...
