CK 30 stiff 4WD shifter
   / CK 30 stiff 4WD shifter #21
Hello Guys, the 4wd is somehow syncronized with the steering . The best thing to do is spray your linkages underneath the tractor with lithium grease, you can buy it at about any automotive store. All i do is stop the tractor, apply the brake while gently pulling up on the 4wd knob and turning the steering wheel all the way to the RIGHT, it will fall into gear easily very time, no need to lift the front end with the loader. This info was given to me by a Kioti tech and it works every time.. Matt
   / CK 30 stiff 4WD shifter #22
Hey Matt!
You passed along this tidbit back in 2008 in this thread:
http://www.tractorbynet.com/forums/...6939-kioti-35-will-not-shift.html#post1475073
In 2008, it was all the way to the LEFT. So, it works all the way to the right also? I have not checked turning the wheel all the way to the right.
Don
   / CK 30 stiff 4WD shifter #23
Hey Don, i must have mis spoken then, it is to the right, I guess i must be getting old.. . You know what they say , The mind is the second thing to go...hehe Matt
   / CK 30 stiff 4WD shifter #24
Well then, I do believe we have just established that sync'ing of the gears works when turning the steering wheel all the way to the right -or- all the way to the left, to engage the FWD. :cool: You heard it here first!
Don
(APPROX. 480BF) 1X6X6-16 WHITE PINE TONGUE & GROOV (A52706)
(APPROX. 480BF)...
Heavy Duty 44in Excavator Rake (Fits CAT 305) (New/Unused) (A59225)
Heavy Duty 44in...
1287 (A58374)
1287 (A58374)
(2) MULE PLOWS & FERTILIZER DISTRIBUTORS (A52708)
(2) MULE PLOWS &...
2021 Allmand Bros Maxi-Lite II 20kW Towable Light Tower (A55973)
2021 Allmand Bros...
20ft x 30ft Steel Carport (New/Unused) (A59225)
20ft x 30ft Steel...
