CK 30 stiff 4WD shifter
/ CK 30 stiff 4WD shifter #21
Hello Guys, the 4wd is somehow syncronized with the steering . The best thing to do is spray your linkages underneath the tractor with lithium grease, you can buy it at about any automotive store. All i do is stop the tractor, apply the brake while gently pulling up on the 4wd knob and turning the steering wheel all the way to the RIGHT, it will fall into gear easily very time, no need to lift the front end with the loader. This info was given to me by a Kioti tech and it works every time.. Matt
/ CK 30 stiff 4WD shifter #22
Hey Matt!
You passed along this tidbit back in 2008 in this thread:
http://www.tractorbynet.com/forums/...6939-kioti-35-will-not-shift.html#post1475073
In 2008, it was all the way to the LEFT. So, it works all the way to the right also? I have not checked turning the wheel all the way to the right.
Don
/ CK 30 stiff 4WD shifter #23
Hey Don, i must have mis spoken then, it is to the right, I guess i must be getting old.. . You know what they say , The mind is the second thing to go...hehe Matt
/ CK 30 stiff 4WD shifter #24
Well then, I do believe we have just established that sync'ing of the gears works when turning the steering wheel all the way to the right -or- all the way to the left, to engage the FWD. :cool: You heard it here first!
Don
UNUSED WOLVERINE MCB-11-48W 48" HYD 4N1 BUCKET (A64281)
UNUSED WOLVERINE...
2015 Isuzu NPR HD Septic Pump Truck (A62613)
2015 Isuzu NPR HD...
2022 BOBCAT T870 SKID STEER (A64279)
2022 BOBCAT T870...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
(2) 380/85R28 TIRES W/ (10) LUG WHEELS (A64280)
(2) 380/85R28...
2023 Unverferth 3PT 6 FT Perfecta Field Cultivator (A63688)
2023 Unverferth...
Here are some similar links:
