CK 30 OIL OVER FILL
   / CK 30 OIL OVER FILL #21
thcri said:
Kentrogun,
My dipstick comes through the side panels. When a tractor has been sitting and is cold your talking ten seconds to pull the stick and see where the level is. You don't even have to wipe the stick, pull it out, check level, put it back in. A ten second process. Common sense tells me to check it every time when your talking about a motor that is as expensive as it is.
murph
Murph, couldn't agree more. Re-read what I wrote. I check mine VERY often. Hard lesson learned I might add.
   / CK 30 OIL OVER FILL #22
The CK30 has no site glass for the tranny. It does have one for the front axle but you have to add way more than the specified amount of gear lube to get it up to the midpoint of that glass.I have ridden plenty of motorcycles with site glasses on the engine case for engine oil level. Perhaps the site glass is a weaker and more failure prone design than a dipstick.
   / CK 30 OIL OVER FILL #23
Highbeam said:
.... Guys, I really don't have a problem with checking the oil level as often as you wish. I don't think it is a required step crucial to the longevity of your machine IF you are confident that you have got everything else under control....
Haven't you ever thought you did something only to find out later, you didn't? Forgot to tighten a bolt, put on your seat belt or left the curling iron plugged in?
Many a confident pilot skipped his checklist and paid with his life... get in the habit of making a checklist and using it for maintenance tasks. Then the only thing you have to do is remember where you put the list! :)
   / CK 30 OIL OVER FILL #24
I forgot to put the plug back in a 9270 CIH 4WD once... oil was running out all over the ground when I started to fill it... Me and my FIL each overfilled my old lawn mower and saw the same white smoke. I did it on my first oil change.... i could just not see the oil on the stick... he did it trying to help me out... put in the same amount his took... excoet mine took have as much... and mowed for an hour before it puffed.... had oil all the way back into the bowl on the carb...changed plug and drained everything.... oil on the muffler took 45 mintues to burn off, but she ran fine after that... till the tranny burnt up... that's another story and it lasted a full year from when I abused THAT.... Cross your fingers... with any luck you will be OK.
   / CK 30 OIL OVER FILL #25
MossRoad said:
...or left the curling iron plugged in?
Whoa cowboy. I was right with you right up until the curling iron part. :eek:
Now, I admitted that I left the oil drain plug out by accident, but you'll never catch me ever admitting that I left a curling iron plugged in!
   / CK 30 OIL OVER FILL #26
What can I say... I have a wife and daughters. That's my story and I'm sticking to it! :rolleyes:
Update from the Dirtcutter. For various reasons I couldnt get to a dealer however one of my friends is a diesel mechanic and he took a look at my ck30 for me. He felt that the motor should me fine and the white smoke was from the mix of fuel and oil. I also spoke to my brother who his an heavy equipment operator he felt I didnt do that much damage, because I stop the engine when the white smoke first appeared. I have put on about six hours of hard tractor work in the last week and everything seems ok. Only time will tell but I think I dodge a BIG BULLET and you know from now on I will always double check.
   / CK 30 OIL OVER FILL #28
I forgot to mention on that lawn mower engine that had been over filled twice... it is still running... we took it and used it to run a log splitter.... still runs like a top! :D
   / CK 30 OIL OVER FILL #29
rback33,
A trick I learned here on TBN is do drill a small "sight" hole in your dipstick(s). I'm pretty blind too anymore but this really helped me. Now I've got sight holes in all the dipsticks.
   / CK 30 OIL OVER FILL #30
The disptick on my vortec 350 in my 98 chevy pickup has 4 site holes installed by GM. Someone had their thinking cap on that day.
I swear , drill a sight hole in the dip stick, what a get idea. The more I log on to this site the more I learn.
   / CK 30 OIL OVER FILL #32
I second that! Dang good idea... I know three small engine dipsticks that will get the drill treatment next week when I get home....
   / CK 30 OIL OVER FILL #33
DIRTCUTTER said:
CK30 bh/fel/ My question is what damage if any did I do to the motor.
Very sorry for predicament you found yourself in. As an Engineer I have a solution for "over filing" or "not filling" in engine crank Case. Can have two 1/2 NPT connection at the side of crankcase for low and high condition, put and elbow and nipple piece with a screw in magnetic float and a sealed reed switch. Wire that up in series (normally closed float sensor) to ignition and motor starting circuit. if one or both condition are met the engine will not start.You then promptly scratch you head and say hmmm. :confused: at least you can not kill the engine till you figure out what you have done wrong. My two cents.
   / CK 30 OIL OVER FILL #34
Sight hole in the dipstick. Great idea! Also, for tractor-hyd fluid,
use the colored stuff. I use Chevron 1000THF, which is maroon.
It is extremely difficult to read a clear fluid level on a dipstick or
site glass.
   / CK 30 OIL OVER FILL #35
Case makes hytrans oil for their machinery that may cross to our tractor's requirements for hydro fluid. It is red like ATF.
2018 HINO CONVENTIONAL TYPE TRUCK (A55745)
2018 HINO...
16ft x 8ft Flat Bed (A57454)
16ft x 8ft Flat...
2449 (A60432)
2449 (A60432)
2018 FORD F-450 XL SINGLE CAB FLATBED SERVICE TRK (A59823)
2018 FORD F-450 XL...
12 X 20 CAR PORT (A58214)
12 X 20 CAR PORT...
2001 BOBCAT 773 SKID STEER (A60429)
2001 BOBCAT 773...
