Ck 25 3 pt all the way up and won't move up or down.
   / Ck 25 3 pt all the way up and won't move up or down. #11
Check underneath that the linkage into the rear end is connected and making things move as they should. If it's not that and the speed valve is working, then something may be wrong internally :(
Might also try removing the weight and then actuating up/down fast/slow.
All the external linkage is connected and moving. I did try it with no weight and no luck with that. Can't afford to disable the tractor right now so ill have to wait untill I have the time to take it apart.
2015 Ford F-350 4x4 Ext. Cab Liberator 3,200LB 1.5 Ton Crane Mechanics Truck (A55973)
2015 Ford F-350...
2017 John Deere 5090GN (A53317)
2017 John Deere...
1998 INTERNATIONAL 9200 TANDEM AXLE DAY CAB (A57880)
1998 INTERNATIONAL...
2012 RAM 5500 Bucket Truck - Cummins Diesel - Automatic - 4X4 - Versalift SST40 Boom (A55302)
2012 RAM 5500...
2016 TRAILSTAR 40FT DUMP TRAILER (A56129)
2016 TRAILSTAR...
2012 Toyota Camry Sedan (A56859)
2012 Toyota Camry...
