Ck 25 3 pt all the way up and won't move up or down.
   / Ck 25 3 pt all the way up and won't move up or down. #11
Check underneath that the linkage into the rear end is connected and making things move as they should. If it's not that and the speed valve is working, then something may be wrong internally :(
Might also try removing the weight and then actuating up/down fast/slow.
All the external linkage is connected and moving. I did try it with no weight and no luck with that. Can't afford to disable the tractor right now so ill have to wait untill I have the time to take it apart.
7021 (A55851)
7021 (A55851)
Ford F450 Bucket Truck with Altec AT200A Boom (A56435)
Ford F450 Bucket...
Weber CR5 Reversible Plate Compactor (A56857)
Weber CR5...
2023 Kubota U48-5 Compact Excavator with Angle Blade and Hydraulic Thumb (A55315)
2023 Kubota U48-5...
2013 Chevrolet Van (A55973)
2013 Chevrolet Van...
Case 1020 25ft Draper Head (A55315)
Case 1020 25ft...
