Snow CK 20S Blowing Snow
/ CK 20S Blowing Snow #1
eastpointer
Souris, PE
Kioti CK 20 S
I have a CK 20S and had my first experience blowing snow with it today ! I have a 54" puma blower on it and they work great together. The only concern that I have is every time I depress the clutch to either change gears or shift from forwards to reverse there is a clicking noise from the underside ?? Is this normal ?? :confused: It is not a loud clicking noise but you can definitly here it and it only does it when the pto is engaged ?
/ CK 20S Blowing Snow #2
If you do a seach for CK20 noise or something similar in this forum, you will find this discussed several times. It is the overrun clutch making a ratcheting type noise. Keeps the implement from driving the tractor and is normal.
Hey thanks so much for the info, I was a little worried when I first heard the noise and wasn't sure if it was normal or not ?? Gotta love tractorbynet.com for getting any info you need and bring on the snow now that I know that noise is normal.
/ CK 20S Blowing Snow #4
As mentioned, that is the overrun clutch and normal. When I disengage the rear PTO, I just slide the PTO lever to off without using the clutch. I use the clutch to ENGAGE the PTO but not to DISENGAGE.
I have a 60" JRW on my CK20HST and it works great on even the heavy wet snow.
/ CK 20S Blowing Snow #5
Many thanks to the "askers" and the "answerers" on this forum. The info is most useful. I've had my CK30 now for just a couple of months, and wondered if disengaging PTO with lever only was appropriate. This is my first contest with the "double clutch" method, but I like the way it works.
1996 Dorsey Enclosed Trailer, VIN # 1DTV11520TA252324 (A57453)
1996 Dorsey...
1042 (A60430)
1042 (A60430)
JD ENGINE (A60432)
JD ENGINE (A60432)
Brock 48'x16' Flat Bottom Grain Storage Tank (A57148)
Brock 48'x16' Flat...
2009 Bruton T/A Enclosed Livestock Trailer (A55973)
2009 Bruton T/A...
UNUSED SDLANCH SDLGC100 ELECTRIC GOLFCART (A60430)
UNUSED SDLANCH...
