circulating engine heater install on MX5100
/ circulating engine heater install on MX5100 #1
docone
Wainwright Alberta
Kubota MX5100HST, B6200D
Anyone out there installed a circulating engine heater on their tractor? (MX5100HST)
Wondering where to install hose port connections for best results.
Any info would be appreciated.
thanks, in advance
Dave
/ circulating engine heater install on MX5100 #2
What year is your tractor? Do you have egr on your engine? If you don't have egr then you can use the port that it uses on the newer engines for the lower port and there is a port on the thermostat housing to use for the other.
Kuboman,
my mx is a 2012 model, v2403 engine w turbo.
/ circulating engine heater install on MX5100 #4
Kuboman,
Yours will have the cooled EGR which means the only available location is used by the egr cooler. You may be able to t into the hoses for the egr cooler. I took off my egr system completely and used the connections for a circulating heater.
Thanks for your assistance, kuboman,
much appreciated.
/ circulating engine heater install on MX5100 #6
Is a circulating heater different than a block heater?
yes, a circ heater has an integral check valve on the inlet and acts similarly to a coffee percolator, heats the liquid, and as it expands it moves thru the chamber allowing cooler liquid to enter and repeating the process. a block heater sits in a coolant journal and relies on conduction to warm the engine.
Circ heaters are more efficient, and therefore require less time to do the same job.
/ circulating engine heater install on MX5100 #8
Interesting, I'm going to have to look at these prior to ordering a block heater.
/ circulating engine heater install on MX5100 #9
These work awesome for sprint cars.
The Hot Setup Engine Heater
Hot Shot Sprint Car Engine Heater
2015 K and K Systems Towable Solar Arrow Board (A61572)
2015 K and K...
2008 Kaufman Wedge Trailer (A62613)
2008 Kaufman Wedge...
2015 Ford Explorer AWD SUV (A61574)
2015 Ford Explorer...
(1) 24X9.50-12 TIRE W/ 5 LUG RIM (A64280)
(1) 24X9.50-12...
UNUSED WOLVERINE RSB66-66" ROCK SCREENING BUCKET (A64281)
UNUSED WOLVERINE...
Zuidberg Front 3pt and PTO Kit (A63117)
Zuidberg Front 3pt...
