circulating engine heater install on MX5100
/ circulating engine heater install on MX5100 #1
docone
Wainwright Alberta
Kubota MX5100HST, B6200D
Anyone out there installed a circulating engine heater on their tractor? (MX5100HST)
Wondering where to install hose port connections for best results.
Any info would be appreciated.
thanks, in advance
Dave
/ circulating engine heater install on MX5100 #2
What year is your tractor? Do you have egr on your engine? If you don't have egr then you can use the port that it uses on the newer engines for the lower port and there is a port on the thermostat housing to use for the other.
Kuboman,
my mx is a 2012 model, v2403 engine w turbo.
/ circulating engine heater install on MX5100 #4
Kuboman,
Yours will have the cooled EGR which means the only available location is used by the egr cooler. You may be able to t into the hoses for the egr cooler. I took off my egr system completely and used the connections for a circulating heater.
Thanks for your assistance, kuboman,
much appreciated.
/ circulating engine heater install on MX5100 #6
Is a circulating heater different than a block heater?
yes, a circ heater has an integral check valve on the inlet and acts similarly to a coffee percolator, heats the liquid, and as it expands it moves thru the chamber allowing cooler liquid to enter and repeating the process. a block heater sits in a coolant journal and relies on conduction to warm the engine.
Circ heaters are more efficient, and therefore require less time to do the same job.
/ circulating engine heater install on MX5100 #8
Interesting, I'm going to have to look at these prior to ordering a block heater.
/ circulating engine heater install on MX5100 #9
These work awesome for sprint cars.
The Hot Setup Engine Heater
Hot Shot Sprint Car Engine Heater
Geringhoff Adapter (A63117)
Geringhoff Adapter...
SKID STEER AUGER ATTACHMENT (A62613)
SKID STEER AUGER...
2013 Ford F-550 Altec AT37G 37ft Bucket Truck (A61573)
2013 Ford F-550...
Coats 90X-AH-L Tire Changer Machine (A61573)
Coats 90X-AH-L...
2007 Jeep Liberty 4x4 SUV (A61569)
2007 Jeep Liberty...
2002 Schulte XH1500 15ft. Batwing Rotary Brush Cutter Tractor Attachment (A61572)
2002 Schulte...
