Cigarette lighter plug
/ Cigarette lighter plug #1
NHSawyer
Southern NH
Cub Cadet/Yanmar LX410
Hi Folks,
I have a wood chipper that needs 12V to power whatever opens the value in the hydraulic line to power the feed roller. I have always used a small 12V battery for this. I am thinking now of using the cigarette lighter plug on the LX410 in the storage area on the rear wheel fender. Does anyone know where to get one of the cigarette lighter male plugs that I can wire into cable that runs to the chipper?
Thanks
NHSawyer
Thanks guys people on this forum are quite helpful.
/ Cigarette lighter plug #5
You could us an old car cell phone charger, just open it up and use thicker wire. I'm assuming you can solder. :D
/ Cigarette lighter plug #6
/ Cigarette lighter plug #7
Amazon has a lot of 12v outlets available. I installed an outlet on my Deere 4400. I do suggest getting a marine type plug and male fitting as they are made for outside use.
I used mine to power a warning light (mounted on the ROPS) when I was clearing snow.
Here's a link to the thread:
http://www.tractorbynet.com/forums/john-deere-owning-operating/217876-adding-12volt-outlet.html
x2
I picked a very nice marine outlet from West Marine a while back. The receptacle and plug are both covered in that soft, shiny plastic that is sometimes used on the handles of tools - which forms an excellent watertight seal.
Sure beats the heck out of the Autozone receptacle it replaced, whose rubber cap had tendency to just fall off after a couple of years.
Thanks for the ideas. I think I only need the male as the plug is already there on the fender of the tractor and it must be setup for outdoor use. I did notice the marine type plugs and that is what I will buy.
I don't need this just yet as the battery I have been using took a charge so I might as well get my money's worth out of it.
/ Cigarette lighter plug #9
Marine grade is definitely the way to go for exposed/semi-exposed switches & connections. If you planned on lights or any other upgrades for later you could box in and mount a little switch panel for work lights, radio, etc. and only go in the once. Adds to the cost but gives you plug-in options for later. I always get panels with more space than I figure in case I want to tie in more later--keeps things neater.
2016 JOHN DEERE 7210R TRACTOR (A65054)
2016 JOHN DEERE...
SHORTWOOD 5 BOLTSTER LOG TRAILER (A64276)
SHORTWOOD 5...
2009 VOLVO VHD BOBTAIL VACUUM TRUCK (A65643)
2009 VOLVO VHD...
Excavator trenching bucket- one bucket per lot (A63689)
Excavator...
2014 VOLVO A40G WATER TRUCK (A65053)
2014 VOLVO A40G...
New/Unused Landhonor 8ft x 10ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
