Rear Blade Choosing a rear blade - need advice
   / Choosing a rear blade - need advice #11
Jim,
If your tractor has more than 1 position to attach the top link, try using the bottom point. Your lift arms won't go any higher, but you'll probably get more tilt to raise the blade end higher. Just a thought.
   / Choosing a rear blade - need advice #12
Ed,
You mentioned that you planned to do some ditching, so keep in mind that with a 6 foot blade you will probably have to use the offset feature to get the end of the blade into the ditch with the blade angled. I do similar work with a 6 foot Woods blade, and now wish I had gone for the 7 foot blade. A quick test is to have your dealer hook one of the scrapers you're looking at to a tractor with wheel width similar to yours, set it at an angle, and see how far it extends past the tire. Then keep in mind that you'll want your rear tire to stay on the road surface while you are working the ditch or scraping off the road shoulder.
Good luck.
-Scott
2019 FORD F-350 SUPER DUTY SERVICE TRUCK (A58214)
2019 FORD F-350...
JCT 72" Skid Steer Rotary Brush Cutter, Asset# 68 (A59076)
JCT 72" Skid Steer...
1997 Generac T/A Towable 175kW Diesel Generator (A56857)
1997 Generac T/A...
2017 Ford (A55973)
2017 Ford (A55973)
2012 Ford Transit Connect Cargo Van (A56858)
2012 Ford Transit...
UNUSED FUTURE 350 HYD BREAKER HAMMER (A52706)
UNUSED FUTURE 350...
