Chlorine lock on swimming pool?
   / Chlorine lock on swimming pool? #51
So back to the OP's issue about chlorine lock.... I've never heard of it. Apparently it's common?
Nor have I.
I may have an above ground pool installed at the farm for the grand kids. Don't now how they differ as far as maintaining vs in ground.
I could just get the grand kids a couple of cows and chickens, and see if they even notice there's no pool LOL
   / Chlorine lock on swimming pool? #52
Nor have I.
Our above ground has been a piece of cake to maintain. Don't get me wrong, we've had some issues. For example...
Our oldest kid developed a skin sensitivity reaction to chlorine. We switched to Baquacil and used that for probably 10 years. While it worked great, it was extremely expensive and we usually had two pink algae outbreaks every year, where the only solution was to dump $$$$ chemicals in it. And, towards the end of each summer, the water would start tasting metallic. Fall drain down and spring re-fills is what I think was the only reason it worked as well as it did. I'd never recommend it again to anyone unless they had a situation like our kid with the skin reaction.
Kid toughened up over the years, and when we went back to Chlorine, I also converted to salt water. Will never do anything else. It's great!
The salt concentration in our pool is about 3500 parts per million, about equal to the amount in human tears. So you can open your eyes in a salt water pool and feel absolutely nothing uncomfortable. That's about 10X less than the amount of salt in sea water, which is about 35,000ppm. There's so little salt, the EPA considers it fresh water. You can taste it a bit in the water. For that matter, I stopped using test strip for salt levels and just keep adding salt until it tastes good in the spring! :licking:
Its soft water. So your hair (not my hair, I'm mostly bald) is nice and it doesn't effect clothing/swimming suits badly, either. When you get out and dry off, your skin (and mine, too) is nice and soft.
The salt water chlorine generator uses electric current to convert the salt into hypochlorous acid (HClO) and sodium hypochlorite (NaClO). Notice the sodium hypochlorite.... that's liquid bleach. :)
The nice thing is, when it breaks down, it turns back into salt. Salt can't evaporate. Therefore, you don't have to add chlorine, it just keeps converting to chlorine and back to salt.
But you do have to keep your CYA levels correct or you can overwork your SWG (salt water generator), and you have to add muriatic acid to control your alkalinity once in a while. That's $5 per gallon and I use maybe 2-3 per summer. And the SWG uses electricity, so you have to pay for that. However, for us, at least, the pluses outweigh the minuses, in that I rarely adjust my chemistry, I can go on vacation for a week or two and come home and the pool isn't a swamp. All I do is dip my test strip once or twice a week and check, and add my weekly dose of algaecide.
   / Chlorine lock on swimming pool? #53
I also own 12 acres on a river about 10 miles away from the farm I'm moving to. So, Instead of buying a small pool that I would have to maintain, we could just get in the truck and ride over to the river property and let them play/swim in the river ! As far as work and up keep,That would work out great for me !
Now, to see if I can get the grand kids to go for it and I'll be set !
   / Chlorine lock on swimming pool? #54
Where I grew up, we had a 90' escarpment behind the house. It was on the high bank of a man-made oxbow lake that used to be part of the river. My dad built about 150 steps down the bank, and made a wooden chute to send gravel and sand down to the bottom and he built up a beach area down there. We always had a row-boat tied up down there, and a place to swim. It was...
THE BEST PLACE FOR A KID EVER!!! :laughing:
Hi all,
Lots of activity here. As a follow up to my pool problem. Now working fine after a few days of lock. I mentioned last yr was a long process, but this year a short time to get balanced . I suspect maybe my winter cover may have been contaminated from last yrs bug algae etc and was transferred to this yrs water. This year I reacted quickly. Fast action may be reason I solved so quickly. Anyway, I will clean up the winter cover killing anything that might hurt water carrying contaminate to next year.
Talking about swimming in rivers? Reminds me of swimming in Monongahela running north thru Pittsburgh , dumping into Ohio river down stream from Pgh.
50 - 55 years ago as kids we swam in a river that had cat fish or carp about only thing living in water, except germs. We swam past chemical plants, sewerage plants, Steel Mills etc. Raw sewerage, chemicals and what ever. We swam along side of crap floating past us and joked about it. I often wonder how we did such a thing and never seemed to get sick.
Today the Monongahela river is very clean with good eating fish. Great for boating and swimming. It nice to see that it's cleaned up.
Have a good 4th everyone..........Cheers Coffeeman
   / Chlorine lock on swimming pool? #56
I'll add my recommendation for the trouble free pool site. I bought a house that had a pool that had been closed for three years. I never owned a pool before this one. I went to a pool store and after a couple of trips and more money than I want to think about. I found TFP.
Much like here they gave me good advice and I've learned a lot. I now spend about $15-20 a month on bleach, muriatic acid, and occasionally baking soda. The only specialty pool I buy is CYA stabilizer. For the last two years I've been able to open the pool and have it balanced in a couple of days.
I can't say enough about the advice I get there just like here!
2014 CATERPILLAR 308E2CR EXCAVATOR (A52709)
2014 CATERPILLAR...
2012 MACK Tender Truck w/ADAMS Rear Discharge Bed Auger (A56438)
2012 MACK Tender...
(4) Motreal ST2051/7515 Tires (A57149)
(4) Motreal...
4 Unused Montreal ST205/75R15 Trailer Tires (A55788)
4 Unused Montreal...
Pull Type Concrete Mixer (A57453)
Pull Type Concrete...
9ft 4in Flat Bed (A57453)
9ft 4in Flat Bed...
