MossRoad
Super Moderator
- Joined
- Aug 31, 2001
- Messages
- 65,624
- Location
- South Bend, Indiana (near)
- Tractor
- Power Trac PT425 2001 Model Year
I've had similar issues, it's almost always caused by cya (cyanuric acid). It builds over time and that may be why it hasn't been an issue. Unfortunately if it's high the only fix is to drain some water and refill. You don't need to drain it all. Test kits or the pool store can test the level to confirm....
Less likely, but PH can also make chlorine not work, so I would check that too. Once it's all balanced make sure to brush everything down (preferably with a wire brush if the pool can handle it). That can help expose all the Algae to the chlorine. Nothing more frustrating than balancing a difficult pool.
That's one of the reasons above ground pools around here don't experience much trouble.... they get about 1/4 of their water drained each fall and replaced each spring. Then the rains, and such, and its common to get 1/2 your water changed every year at a minimum. With the pools only being open about 3-4 months a year, it doesn't have time to get out of whack.
