CHIPPERS
/ CHIPPERS #2
I am not sure if you tractor will handle the chipper I have or not (it weighs about 1500 pounds), but I have a Woods 8100 w/hyrdaulic feed, and absolutely love it. It will take up to an 8inch log and spit it out in seconds.
If you can afford a hydraulic feed option, it is defintely worth it, makes work go much quicker...you don't have to stand there and feed the limbs in...throw it in and while it getting pulled in, you can be getting the next piece.
Not a cheap chipper, but if you view it as a long term investment, it gets easier to justify (at least thats what I keep telling myself)
Good luck.
/ CHIPPERS #4
I paid $7600, that was about $1000 off of list if I remember correctly. The PTO power requirements are not that big, 40HP, but given the size and weight of the thing, I am not sure I would want to lug it around with a small tractor. Even on my big JD5410, it makes it feel very likely to roll over because of where you are carrying the weight (up high, while in transport), but once you get it to where you want it, and start it up, it really is quite impressive.
/ CHIPPERS #5
ejb - When you decide you want to trade up, let me know. I'd sure like to have a chipper like that.
Mark
/ CHIPPERS #6
Now there's the only reason I just have this little 5hp Sears chipper/shredder instead of a real one./w3tcompact/icons/smile.gif
Bird
/ CHIPPERS #7
This one was very expensive, but one of the main chores I have around my place is reclaiming thousand (and thousands) of feet of overgrown rockwalls, thinning the forest and putting in a lot of walking trails around my place. You can't always burn (Jan-Apr only), and even when you can burn, you can't always build a big inferno way out in the woods without risking a wildfire, so the chipper was the best solution for me.
I could rent a similar capaciy machine, at $250/day, but it takes me 2 hours round trip to get there and back (and then another 2 hour trip to return it), which really eats into an 8 hour day rental <g>.
I am not sure I'll ever need to trade up, but if I do, I'll let you know...
/ CHIPPERS
The L2900 has a PTO lift capable of about 1400 lbs and a 25 HP diesel. Anybody using anything that will work in that power window?
/ CHIPPERS #9
Woods also makes a smaller version, will take upto a 4inch log, but I don't think hydro is available for it...I can't remember the model number but its at <url>www.woodsonline.com</url>
/ CHIPPERS
I posted this a while ago, but here it is again.
Andy
PTO Woodchipper Report
Last week I purchased a PTO woodchipper for use with my B2400. I had been looking at different brands for a couple of years. I decided on the Danuser model 18P. This is a 4 inch chipper with power feed. Even though it is rated to take 4 inch diameter wood, the actual infeed opening is 6 inches square. This aids in fitting branches through the opening without getting jammed. The power feed is gear driven off the chipper power shaft and feeds at 55 feet per minute. Many other brands have hydraulic power feed. The gear drive does not allow the feed to be reversed in the event of a jam, however it does not require a hydraulic connection to the tractor.
The chipper is built of heavy gage steel with hefty bearings and shafts. The 106 pound flywheel turns at 1280 RPM with 540 RPM PTO speed and there are 2 cutting knives. Most of the other brands have the flywheel turn at 540 RPM. A slower flywheel stores much less energy than a faster turning one. The higher speed also results in more cuts per minute even though some of the other brands have 3 or 4 blades. The speed increase is accomplished with belt drive. These pulleys have 8 belts side by side to handle the torque load. The belts act as a mechanical fuse if things get jammed, preventing damage to either the chipper or the tractor.
The chipper is rated for 18 to 45 HP. My B2400 is on the bottom end of this rating producing 18 PTO HP. I did succeed in stalling the tractor on a piece of 3 ½ inch dry maple. The tractor stalled after about 7 feet and yes the belts did squeal when this happened. I guess I should have disengaged the power feed. Interesting enough the tractor RPM never even never dropped on anything else I chipped all weekend including some 4 inch oak.
The chipper has a built in fan on the back of the flywheel that lifts the chips up and discharges them out a chute. I built a plywood extension and top for my trailer and shoot the chips into it.
I am satisfied with the quality of construction and ease of operation. The power feed is great. I decided on the power feed because it will pull small branches and vines as well as the large stuff right into the chipper. It eliminates kickbacks which can happen with the last foot or so of the branch without power feed. It is also rated as quieter than many other chippers.
I paid $3475 for the 18P, the model without power feed (18G) was $1000 less but is being discontinued. The first dealer raised the price $600. since I priced it with him last fall. I contacted the manufacturer and was told the list price had increased $100 during that time. I found another dealer that sold it to me for $75 more than I was quoted last fall.
The company web site is at: http://www.danuser.com/chippers.htm#specifications
Other chipper web sites are:
Roberge http://www.comsearch-can.com/cpe5.htm
Bear Cat http://www.crary.com/bearcat/index.html
Vermeer http://www.vermeer.com/eq_brush_chippers.html#Anchor-BC625
Chippit http://www.entectradingltd.co.uk/chippit_pto/chippit_pto.htm
Gravely http://www.gravely.com/index.phtml?pg=Xherochipper
KwikChip http://www.fletcherstewart.co.uk/ptochip.htm
Ram http://www.rampower.com/products.htm
Befco http://www.sledmaine.com/dealers/whittemr/befco/buschip.htm
Woods http://www.woodsonline.com/
/ CHIPPERS #11
Looks like you did a lot of research. I haven't, since I can't afford one right now, but the last time I was in my Kubota dealer's place, I noticed a Bear Cat chipper in the showroom; it looked good to me, but I really don't know much about them.
Bird
/ CHIPPERS
Unless I am mistaken that chipper sold by Northern is the same as the Mackissic Inc chipper. I think they make it for Northern. I looked at an almost new Mackissic chipper mounted on an 8N. It is really a light duty machine and is designed to run much faster than 540 RPM (1000 would be better). It was very slow chipping at 540 RPM. If I remember correctly (2+ years ago) it only had 1 cutting edge mounted on a very light duty flywheel. The spindly little legs were bending where they attached to the chipper. The 3 PT mounts were so light duty they bent back and forth every time the 3 PT raised or lowered the chipper. They were all bent out of shape from this on the one I was looking at. The guy wanted $1000 and I would not have given him $100 for it and it was pretty new.
Andy
/ CHIPPERS #14
Andy - Good info. I'd forgotten about it, so thanks for reposting it. I'd recommend anything Danuser makes to anybody pretty much without seeing it, much less using it. Their stuff is very good. I even met Mr. Danuser himself at the Louisville Farm Show this year - very nice fellow. But I'd forgotten they make chippers. Sounds like they're pretty reasonably priced for the quality, which is very high, if Danuser builds it.
Mark
/ CHIPPERS
I went through this a few years ago too and here's what I found.
The Bear Cat and Woods are identical chippers. I don't know who makes it for whom, but they are the same. It's a chipper/shreader so it's a good pick if you want the shreader. I didn't.
I looked at some of the higher-end chippers and they were beyond my price range (>$3000) or required a larger tractor (I have a B2400).
I settled on a Patu DC40. It's rated for 4" and has a manual feed. I've been VERY happy with it, even the manual feed. It really does a reasonable job of self-feeding, especially with the big wood. I've fed it all types of wood up the the biggest size I can get into it (which is more like 5") and it just chomps right through it. Truely amazing. It costs about $2600 new. I got mine used for $2200 if memory serves me.
There is also a DC 60 which is a 6" model.
Here's a link with info. Looks like there is a hydraulic feed model available too.
http://www.kesla.fi/eng/dc40mf.html
John Deere X500 Riding Lawn Mower (A66285)
John Deere X500...
2016 GMC Sierra Flatbed Truck, VIN # 1GD42WC83GF101701 (A65563)
2016 GMC Sierra...
New Quick Attach Power Spreader (A65579)
New Quick Attach...
2007 Sterling L9500 Fuel & Lube Y22693 (A62613)
2007 Sterling...
JOHN DEERE R4023 SELF-PROPELLED SPRAYER (A64277)
JOHN DEERE R4023...
John Deere 660 Hay Rake (A66408)
John Deere 660 Hay...
