chipper and CK20 HST
   / chipper and CK20 HST #1
oldernwiser
maine
KIOTI CK20 HST
Have a need to replace my TroyBilt 15 year old chipper for something with a little more gusto. I was entertaining a PTO driven chipper for my CK20. Does anyone have any input as to what size or mfg. of chipper would would be appropriate for the CK? am getting a little confused as to HP requirements vs. PTO horsepower. Some makes do not distinguish between the two. Any input would be appreciated.
John
   / chipper and CK20 HST #2
I've been going over this same question myself. I have a 2015 Mahindra. The specs on you tractor say 15.5 hp at the PTO. When it comes to HP requirements, I'd always assume they mean at the PTO. Reason is, a CK20 and CK20 HST are both 21 HP tractors, but the gear drive has more ponies at the PTO. That's the case in all makes and models.
I've been looking at the DR chipper. It seems pretty beefy for light to moderate use. Very low maintenence, but only has one cutting blade. If you need something heavier, look at Wallenstien, and Salsco. There are Salsco machines that can run on as little as 8 PTO hp. They are kinda pricey but everybody gives them good reviews.
And then there's the Jinma Chipper. I don't know much about them. They are a power feed unit, and recommend at least 18 PTO HP I think.
I haven't yet decided what I'm gonna do yet. Thinking DR or Salsco.
   / chipper and CK20 HST #3
I have the DR unit and have been very happy with it. I bought the bottom discharge unit ,but if I could do it over, I'd go the extra $$$ and get the chute model. Much more conveinient not having to constantly move the chip pile. I have the 3054 with an ADVERTISED 24.5 HP pto;but who really knows. I bought it as a 30.5 HP tractor and it later turned into a 28????? The DR unit has been trouble free and seems to be HP friendly;that is does not need a bunch. I run the tractor at 1450 RPM utilizing the 1000 setting for the pto,which gives me a little better than 540 pto RPM and have yet to stall either the chipper or the tractor. I hate hearing the tractor turning 2600 while chipping two to three inch stuff;everything bigger gets cut for fire-wood.
   / chipper and CK20 HST #4
Patches,
On the DR. I was concerned about the feed rate, and the length of time you get out of the single blade. I may not use the chipper for weeks or months, but when I do it will be an all day deal for several days. Can the DR stand up to that in you opinion??
And just for reference, how long would you estimate it takes to chip a 4 inch pine log, 5 feet long? I'm just trying to picture it.
   / chipper and CK20 HST #5
driver444; I don't think you would have a problem with the usage you describe as all of my chipping is oak and maple, but as stated, on the small side (2"-3") If I had to guesstimate a time frame for your 4" pine, assuming it is green, I would think you could chew through it in less than 45 seconds. The unit has a limited "self feed" capability provided by the approach angle of the material and the cutter is double sided to provide a reasonable life cycle;and they aren't terribly expensive to replace if your not into the sharpening thing. This having been said, if you have 4 or 5 acres of pine to clear you might be better served by renting a commercial unit
   / chipper and CK20 HST #6
There is a TBN member that is using a Wallenstein BX42 chipper on his CK20, and as far as I know he has had very good results with it. I saved a picture, but haven't found the thread.
   / chipper and CK20 HST #7
That is a good deal larger than the DR and if the chip pile is an indication, works well.The DR is just a tick under $2,000;what does that beast cost?
   / chipper and CK20 HST #9
well guys i just bought a jinma 6 inch chipper for my ck20 hst and so far i love it. it chips what i need 3 to 4 inchs nice.wood biger that 3 to 4 i"m going to burn.i"ll try some biger stuff and let you know. like i said i just got it today.
   / chipper and CK20 HST #10
I am looking at a Wallenstein BX42. The good part to me is that it comes fully assembled and the dealer is not too far away. A common remark on TBN about the Jinma, is that it is a good machine as long as you go through it, upgrade belts, and tighten all the bolts. For the little difference in price, I figure it is better to have a dealer that will stand behind the purchase.
They are quoting a price of $2300 and if it looks as good in person, I'll probably take it home with me.
The Salsco was another choice I explored but it looked to me like the Wallenstein hopper was better designed to accept limbs. If you want to go with a hydraulic feed, then the Salsco would be a great choice, but the price for the 824 goes up to $6300. From my research, the Wallenstein seems to be able to work well enough to not need the hydraulic feed. Time will tell, and I'll keep the list informed about my purchase.
2017 Vermeer SC802 S/A Towable Stump Grinder (A50322)
2017 Vermeer SC802...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
2012 ISUZU NPR 18 FT FLATBED (A52141)
2012 ISUZU NPR 18...
JMR Attachments Tree Boom (A50121)
JMR Attachments...
2010 Chevrolet Tahoe SUV (A50324)
2010 Chevrolet...
Poly Round Bale Ring (A50515)
Poly Round Bale...
