Chip Sealing Driveway
/ Chip Sealing Driveway #21
Not sure of costs in your area but tar and gravel about 60 percent the cost of asphalt maybe less depending on the size of the job. Should be applied in three coats to get you the best bang for your buck. The tar used in our area is called CRS 2 and is water based so no harm to the environment no hazmat license required to haul. When finished should be about one inch thick
Buppies is a tar water emulsion what you are thinking. That is commonly used for thin coats of maintenance road coatings
/ Chip Sealing Driveway #22
The Earwigs go into the Diesel Filler Nozzles, like it`s not a bad place to live!.
/ Chip Sealing Driveway #23
1968 - Palmer, AK. DOH contractor lays down tar & chip on one half of the state highway going thru Palmer. About five miles worth. Roller is done - that half is still blocked off. Something happened - here comes the AK State police - he looks like a blinking Christmas tree. He swerves out onto the new tar & chip section to avoid the contractors equipment.
The tar & chip coat rolls up on his cruiser tires - just like a jelly roll. He gets about 80 feet and is brought to a quick stop. Something with the materials used or the process is WRONG. We were in the strip mall parking lot and saw the whole thing. At first everybody kept it contained - then one person began laughing - uncontrollably. That's all it took. An entire crowd burst out laughing. The highway patrolman got out of his cruiser and the crap stuck to the bottom of his boots also. I can hardly contain myself, right now, as I remember this scene.
It even made the evening news in Anchorage. Bottom line - the entire job had to be scraped up and new laid down.
They did that about 10 years ago to a local road. County paid out many $$ to motorists filing claims about the excessive tar/gravel stuck to their car (long after the road should have been fine).
/ Chip Sealing Driveway #24
I remember as a kid walking on those roads barefoot in the summer. Funny, I just remembered the smell.
Chip seal is usually 1/5th the cost of asphalt, is what I was told in my area. Typically private driveway jobs are done when they have a larger project lined up in the area.
One part of my driveway is about 9-12 degrees pitch but that is only for maybe 50 feet and then it levels to a gentle 2-5 degree pitch. This is NOT "grade" as found on highways. That is measured differently. I just used a gauge that reads off degrees.
/ Chip Sealing Driveway #26
I have a 1,600 foot long by 10-12 feet wide driveway that is currently gravel AB (mag spec 3/4" minus rock with fine sands). It's a good road base but getting sick of the dust and rocks.
Just wondering the costs to have a driveway my length, chip sealed? Since I already have the road base, just looking to have the tar poured and the chip seal laid and rolled.
Its cheaper than asphalt and durable like toilet paper.
If you have frost or heavy trucks/tractors/machinery you will be unhappy with tar and sht oops I mean chip. It also washes out real easy...
/ Chip Sealing Driveway #27
That's what I was thinking. My driveway is like a sponge in the spring, and I can't see the chip-n-tar surviving that. Excavate the whole thing down to hard pan or bedrock, put in a good base and you might have something to work with. Otherwise, I could forsee a big mess and total waste of money.
Depends on location/climate. Where I live, entire state and county roads are chip sealed and they see 30,000 vehicles of traffic per day on them and the roads are nice and smooth. DOT in my area allows for 20+ ton trucks to drive on chip sealed roads.
So a broad general comment like that doesn't work as location/climate play a huge role. On soft clay soils with heavy precipitation and snowfall vs bedrock and dry climates, is a night and day difference in how the road base will react to chip sealing. Just like there are different building code requirements based on location/climate, so the same applies to what works and what doesn't work with road materials.
/ Chip Sealing Driveway #29
A municipality has deep pockets to make the roadbed right.
/ Chip Sealing Driveway #30
In southern Ohio many of the local and county roads are tar and chip. Minimal work to subgrade prior to paving
/ Chip Sealing Driveway #31
Streetcar if one wants RC 250 must drive 3.5 hours to obtain one way. Have done numerous roads driveways with CRS 2 no complaints and it is approved by our DOT and local government agencies
/ Chip Sealing Driveway #32
That's why our municipality tore out the *NEW* tar and chip on our road after 3 winters and replaced it with asphalt this summer. They were spending more on hot patch making pot-hole and shoulder repairs than the original tar and chip job.
Why spend once when you can spend 8x as much!
/ Chip Sealing Driveway #33
Might want to check out Perma-Zyme. It's a soil stabilizer. Might work for what you want to do in keeping dust down. When I was researching something for a piece of property I found it. Just google or search engine of your choice.
/ Chip Sealing Driveway #34
Crs 2 is an asphalt water emulsion
/ Chip Sealing Driveway #35
You are correct been using on city alleyways for 8 years and subdivision roads 10 years no issues for us. VDOT approved and used throughout our region
/ Chip Sealing Driveway #36
I would suggest to the op that they check with resident engineer for their DOT region and ask them about tar and gravel. Most I have dealt with are more than happy to share their knowledge
/ Chip Sealing Driveway #37
Buppies
How high of traffic volume on subdivision streets with tar and chip
/ Chip Sealing Driveway #38
Do you live in a hilly area?
We have lots of hills and ups and downs. Everyone has gravel driveways in the remote areas.
Went garage saleing and found one guy who got together with a couple neighbors and had the 1 lane road paved.
They were very unhappy.
Any frost or ice and they cant get up the road anymore
Like I mentioned before. It all depends on climate/location. In desert SW areas where there is very little to no snow during winter, chip seal works perfectly fine and at 1/5th the cost.
/ Chip Sealing Driveway #40
It's used a lot here too, on nearly every rural road. Some companies offer it for driveways too. Most roads hold up because they are updated with a fresh tar/chip coat every several years. As long as that's done before the road is too deteriorated, the multiple coats are built up and provide a very nice road long term. They even use tar/chip on some larger county roads and small state routes, as a top coat to an aging paved road. That seals and rejuvenates the surface for a few more years before a total repave is necessary.
2010 Case 580N (A60462)
2010 Case 580N...
2013 FORD F350 SUPER DUTY 4x4 CREW CAB PICKUP TRUCK (A59910)
2013 FORD F350...
2022 New Holland C327 Compact Track Loader (A63118)
2022 New Holland...
LILLISTON 2R ROLLING CULTIVATOR (A63290)
LILLISTON 2R...
JLG SCISSOR LIFT (A63745)
JLG SCISSOR LIFT...
2007 Ford F-750 Water Truck w 2,000 Gallon Tank (A63118)
2007 Ford F-750...
