Re: this subject
Maker,
Sorry, was busy picking-up my new Jinma 284, FEL, and BH, from Newark port. Its always fun to recieve new toys, regardless where they come from! /w3tcompact/icons/grin.gif
Appreciate that you went through the reasearch to determine if the tractor was right or wrong for you. Most wouldn't have took the time. I would recommend visiting a dealer and inspecting a tractor to be high in priority in this reseach, though. Rural King, which I believe is scattered around IL, sells a Jinma.
The Jinma tractors do not have a shop service manual per say, available from JM. Don't know if the larger dealers, Agracat, Northern, make there own manuals or not. They do come with an Illustrated Parts Break-Down manual and Operations manual. The Operations manual is more that tractor operations. It covers many adjustments and procedures. These procedures take up more than half the manual. I have the official 3" thick Ford service manual specificly for 1997 Taurus. It is difficult to use and requires numerous Ford special tools. There are no special tools required for these tractors.
The Jinma 204 through 284 are assembled on an assembly line. I hear the the larger series are hand assembled. I would guess that there are other Chinese brands could be hand assebled, as well. So, there is some basis of fact, that the dealer reported to you. Important to know what brands and what time frame. Four-five years ago, Jinma, was much different then it is today.
Not knowing what a used Yanmar requires to prep, can't compare the times. Assembly and check-out does take time, and is key question to ask a dealer. Experienced Chinese tractor dealers are highly recommended. If a dealer is just slapping them together, look elsewhere.
Hey, at least you gave us credit for help keeping the big 3 in check. Don't think they are concerned with the Chinese yet, but it will come. In my case, which is not typical, I saved at least 1/2 of the cost of a 28hp gear drive Big 3, FEL, and BH. For the less than 250hrs a year I will use it, I am willing to put up with any of the issues.
My 6', 250lb frame, requires careful getting on and off the tractor. It has many levers, the transmission between your legs, and smallish deck, require careful foot placement. Thought this would be something you needed to know.
Good luck in your tractor search. I would be interested in hearing on what you decide on for your "spare" or second tractor.
