Chinese mini dumper stalling in reverse-what to check?
   / Chinese mini dumper stalling in reverse-what to check? #1
2manyrocks
Super Member
I bought this Chinese mini dumper at auction for a little over $1,300 because I wanted an inexpensive track machine to work with in a tight area infested with honey locust thorns. The machine appeared to be unused and still had inventory tags on the rubber tracks when I picked it up from auction.
The problem I'm having is the machine stalls out completely and kills the engine when the control levers are moved to reverse by pulling back on them towards the operator position. The engine also stalls slightly when the controls for the front bucket and the tipping container are pulled back towards the operator. The machine appears to operate normally going forward, but stalls out and kills the engine when I try to reverse by pulling back on the operating levers.
It appears to have adequate hydraulic fluid although the marks on the dipstick and the sight tube seem inconsistent with each other. When I added hydraulic oil to get the oil level between the marks on the dipstick, the sight gauge then looked over full. Going into reverse still stalls and kills the engine.
Any ideas what I should check next?
Didn't find anything specific to this kind of dumper machine, but the FB chinese mini forums seems to generally recommend changing the hydraulic oil before operating any of the mini excavators or mini skid steers. Changed out the hydraulic oil with some TSC 46 hydraulic oil. Didn't see any metal flakes or shavings on the filter so I reinstalled it. Maybe I should have washed it out first? I don't see signs that this machine has been operated much at all so I'm guessing it doesn't matter at this point.
The other usual suspect mentioned in the FB forums appears to be the control valves themselves and/or the pressure setting on them. Upon closer inspection, it looks like the nuts on the pressure settings have been rounded over as if someone already tried to make an adjustment. They were so tight that I left them alone.
Running the machine again, the hydraulic cylinders seem to run smoother now. The machine will also go into reverse if I treat the levers like on/off switches and don't try to feather them. Feathering will still stall the machine, but instantly going into full reverse seems to now work.
   / Chinese mini dumper stalling in reverse-what to check? #3
The pictures show a double gear pump. I suspect one pump feeds left track and other feeds right track. Is this correct?
Would suspect that while trying to feather the track drive the valves are restricting flow to the point of reaching close to system relief pressure but that is something you would need to check with pressure gauge.
what other function does each valve stack control? Does running the other function on both valves simultaneously stall or strain the engine?
My guess is that you need to check the system pressure on each pump section. Suspect they both should be the same pressure and may require adjustment
One pump feeds the L track and the other feeds the R track. The valve stack on the left as you are standing on the operator platform controls the L track and the dumper tub cylinder. The valve stack on the right controls the R track and the front bucket cylinder.
I haven't tried to run both the tub and bucket cylinders at the same time.
When I first tried to lift the front bucket at the auction yard to load the machine, it would completely stall and kill the engine, but it is now running smoothly after changing the hydraulic oil provided that I don't try to feather the valves.
I don't have a hydraulic pressure tester, have never worked with one, and don't know how to connect one to this system. I'm not knowledgeable about working with hydraulic systems.
   / Chinese mini dumper stalling in reverse-what to check? #5
Are there any marking on the the blocks bolted to side frame that I believe are labeled LTR and RTR which i presume is left track and right track. It looks like there is valve sticking out one end but can't see the back side. These could be some form of pressure control for the track motors or possibly counterbalance to prevent machine from running away when driven on a slope.
If you don't have any pressure gauge please do not just start turning adjustments to see what happens.. You may not like what happens if you split a pump from over pressure.
If this was mine I would put a tee in the line from pump to the valves so could watch pressure as operate different functions. Determining what type of fittings were used could be a challenge.
Other challenge may be determining what the system pressure should be set at. I can see what looks like PGP *** on the end of the pump. If you can read that model code we might be able to determine displacement and then try and calculate flows to calculate pressure based on engine HP. AKA a little reverse engineering...
Both the L and R tracks seem to be operating at the same forward speed. I wouldn't want to try to change the pressure settings that would cause the machine to veer to the left or right because of me not knowing what I'm doing.
The pump markings are clear. PGP5133G92 20MPa 4000r/min 2208.
The engine is a 6.5hp Briggs.
The markings on the blocks that feed the track motors appear to have a brand name "Shanyan" with a block connection diagram of C2 C1 V2 V1 and another stamping "VRDL-G3/8" 07/22. The photos on the blocks have been inverted to make it easier to read what is printed on them. They are actually upside down on the machine.
I was curious about the purpose of the blocks. What do you think they are used for?
And thank you for your help.
HTC_pump and blocks_1.jpgHTC Left Block inverted.jpgHTC Right block inverted.jpg
   / Chinese mini dumper stalling in reverse-what to check? #7
2manyrocks,
In that picture of the block for track motors the schematic on the side of the block shows being dual pilot operated check valves C1 & C2 should connect to the motor. Have you driven it down a hill? Curious how it will respond with those po checks in the drive circuit.
I tried a couple of searches and could find nothing on that pump. PGP is a Parker pump series but it is not close to a Parker model code. Doing a little math 3 HP would provide 2 GPM at approximately 2250 PSI
Does either track allow feathering in reverse? If yes does it seem like engine is straining more vs going similar speed forward? Just wondering if something is not piloting one of the checks open in reverse. You might be able to see the hose to the check swell or stiffen if this is happening.
If you are really lucky you might also be able to notice if one or both hoses to the motor are swelling or stiffening while trying to feather the directional valve.
These are non-invasive tests which is my first choice for initial diagnosis since every time you open a line you potentially introduce dirt and or create a leak.
Drove it down a pretty good slope in my yard with a full load of tree debris in the tub without it picking up any speed.
Ground speed is like a slow walk.
Neither track will feather in reverse w/o stalling. Trying to feather both levers in reverse kills the machine, but going full stick in reverse doesn't now.
Although the hydraulic cylinders on the bucket and the tub can be feathered without stalling, both are much smoother if I just go full lever.
The common issue I see is that any feathering on the sticks either slows the machine or kills it entirely if the feathering is done on the reverse levers.
I will try to remember to look at the hoses next time I run the machine. Thanks for that tip. I've never heard of it before.
   / Chinese mini dumper stalling in reverse-what to check? #9
Maybe I can help explain what to look for and why when watching the hoses going to the travel motors.
When trying to drive one of hoses going to the motor will or should free flow through one of the PO checks down to the motor. This hose will see some pressure in trying to drive the motor. If only the one hose stiffens points towards a problem at the motor or track drive assembly.
Other hose to that motor returns flow through the other PO Check that should be piloted open so this hose should have minimal pressure. If for some reason the check is not being piloted both hoses between the check block and motor should stiffen or swell.
NOTE: hoses between valve and check one should stiffen and other should not if check is the problem.
Hopefully above explanation makes sense.
The inability to feather any function is a lack of metering capability of the control valves. Some simply meter better than others.
   / Chinese mini dumper stalling in reverse-what to check? #10
Totally off track (no pun intended) thinking but could problem be with tracks..... Something binding tracks in reverse and stalling hydraulic motors.... BUT works well going forward.... Because the logic for hydraulics to run track motors is the same whether going forward or reverse....
Maybe jack it up and pop tracks off and see what it does, or maybe put it up on blocks so there is no load on tracks...
   / Chinese mini dumper stalling in reverse-what to check? #11
Interesting thought on track binding but why does it work full speed reverse and not when trying to operate at less than full speed? If this unit has blade on front should be easy to lift both tracks off the ground with blade and bucket and see what happens.
Duhh this is a dumper not a mini ex so jack it is.
Track binding or resistance in the track rollers could play into this, but my number 1 suspect is something hydraulic related.
When I first went to the auction yard to load the machine, it had difficulty even lifting the front bucket without tending to stall the engine. It was parked close behind a mini skid steer so I needed to run it in reverse to back away from the mini skid steer, but the engine consistently died in reverse even though the engine itself started easily and ran well. There was enough room to zero turn the machine but that involved several stop/restarts.
Another guy saw me struggling with it. He came over and tried and got the same results.
I eventually got it loaded under its own power and brought it home.
After changing the hydraulic oil and operating the machine a bit more, the front bucket is now cycling much better than it was and the machine will now operate in both forward and reverse by going full stick.
I don't know the history for certain, but I think there's a dealer in the area that imported 20-30 of these that have been sitting in the dealer's warehouse since they were made in 2022. I think they were asking $3,500 and then dropped their retail price to $2,500. There was one that sold in the March 2024 auction for about what I paid for this one, and then this one came along for auction in June.
I mention this out of curiosity whether this time of sitting in the dealer's warehouse with whatever hydraulic oil was in it (it looked okay when I drained it) may have contributed to the hydraulic system tending to stall when feathered? I don't know if the hydraulic oil came from the factory or if the dealer changed it. I mention this because it seems like the machine is doing better just due to being operated?
Will also mention the machine has very little ground clearance and not much protection for the wheel motors.
Raising the machine completely off the tracks with the loader and a jack, I see no difference in the stalling behavior. If I try to feather the tracks, machine tends to stall. If I go full stick F or R, it doesn't.
I haven't tried loosening the tracks. I think I will try operating the machine a bit more to see if it loosens up from operation.
   / Chinese mini dumper stalling in reverse-what to check? #14
Are the hose ends the same where they connect to the motor and PO check block? If yes could you just loop the C1 & C2 ports together? This would remove the track drive motor from the rest of the circuit.
If you can feather the control that would point towards a problem in the motor or track drive assembly
If engine still struggles or stalls the problem is in hydraulic circuit so maybe do same by looping ports on directional valve together to see what happens.
The tracks are slow enough that I am not being jerked around on it by going full stick F and R, but do you think I am I increasing the odds of damaging the machine by operating it when trying to feather the controls stalls it?
   / Chinese mini dumper stalling in reverse-what to check? #16
Not sure on damaging anything going full stick but is concern of system pressure stalling the engine and or what are the pressure spikes when you turn, feather etc.
I think you need to get a gauge and fittings or phone a friend that has them to determine what is going.
JOHN DEERE 644K WHEEL LOADER (A58214)
JOHN DEERE 644K...
CATERPILLAR 259D3 SKID STEER (A60429)
CATERPILLAR 259D3...
Bobcat 863 High Flow Compact Wheel Loader Skid Steer (A59228)
Bobcat 863 High...
2017 Chevrolet Express 2500 Cargo Van (A59230)
2017 Chevrolet...
207281 (A52708)
207281 (A52708)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
